Browse Forums Building A New House 1 Aug 11, 2010 7:02 pm Hi all Just on the finalising stage and unable to decide on the front door. The front entrance is 1475mm. I first thought of having a 820mm width XN6 door with a sidelight. Then decided that I should go for a 920mm width door and the builder agreed for it saying that the sidelight will be narrow, and I was fine with it. Now I am told that with a 920mm door they cannot have a sidelight. I have to decide between a 920mm door without a sidelight or 820mm door with sidelight, and give a decision tomorrow. Can someone tell me whether the sidelight section can be kept as openable. i.e like a double door. Is it possible to get that done and if so appr. how much it would cost? Re: 920mm XN6 Front door and sidelight 2Aug 11, 2010 7:36 pm im inclined to think they can do anything but it will be a special order that the builder may not like i had a quick look at the xn6, i think your saying your choices are either -single 820 xn6 with a 655 highlight (give take architrave), or -single 920 xn6 with no highlight not sure how youd do a double door, i dont think you have the room do you? at least without the one being smaller than the other, you might be able to do 2 720s? If you cant get your double, i'd choose the option with the highlight, you get a lot of light through, and without a highlight its usually quite dark inside the entrance, thats probably a disadvantage of the double doors without highlights, it'd generally be pretty dark Re: 920mm XN6 Front door and sidelight 4Aug 11, 2010 8:35 pm Hi Mav... thanks for that.. Yes, without a sidelight it would be dark.. thats y I am trying to have the sidelight but with a wide entrance.. If I can get a swinging sidelight with 820mm door that would serve the purpose... but dont know whether the builder will agree... Re: 920mm XN6 Front door and sidelight 5Aug 11, 2010 9:25 pm Vasan Now I am told that with a 920mm door they cannot have a sidelight. Doesn't make sense to me... ask again. Timber or aluminium, should be fine. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Building Standards; Getting It Right! AS2047 Section 6 Page 31 speaks to Construction/Tolerances of Windows and external glazed doors in buildings Check also New South Wales Guide to Standards and Tolerances,… 12 20374 I have been looking into getting quotes for a reno I am doing shortly. I have been looking at Trend and Wideline for both windows and doors. I did enquire with Vista but… 0 4680 For your reference Performance Labels: Window assemblies in housing, except timber windows, must be labelled so the label can be seen when it is in situ. For timber… 6 2306 |
