Browse Forums Building A New House 1 Aug 09, 2010 12:02 pm The master bedroom plan is a great layout except the bed is against a wall which has a great view behind it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I'm trying to work out where to position the bed so I can put a large window on the wall. I was thinking a false wall between the retreat and the master suite and put the bed against that ? Might look a bit odd though? Anyone have any suggestions? H's Emperor Q1 on acreage Site cut 16/6/11 Slab 2/8 Frame 29/8 Tiles 9/9 Bricks 13/10 Plaster 2/11 Fittings 28/11 PCI 19/3 Re: Help with bedroom plan 3Aug 09, 2010 4:29 pm My first thought would be - do you want to keep the window at the bottom? If not, easy, switch them around... Could the entry door be moved so you enter the room via the retreat? Then the bed could go against the top wall. Built 3br house in Glenorchy, Tas in 2001 * * * Built 5br courtyard house in Lenah Valley, Tas in 2011 - Homeone thread / Blog Re: Help with bedroom plan 4Aug 09, 2010 4:31 pm The front window also has great views so don't want to remove that one either. The retreat has stairs right behind it, so not really much chance there. But its an interesting thought....... H's Emperor Q1 on acreage Site cut 16/6/11 Slab 2/8 Frame 29/8 Tiles 9/9 Bricks 13/10 Plaster 2/11 Fittings 28/11 PCI 19/3 Re: Help with bedroom plan 5Aug 09, 2010 4:37 pm could you put maybe a half wall to act like a bedhead right where the words master suite are?? My sister has this in her house, but actually has shelves and nooks on the other side for stuff. If you only do a small wall (not all the way to the roof), then it will keep it's openess, but not look silly having a bed in the middle of the room. Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.… 7 10482 Hi, I'm planning to build a new house and wanted to get some feedback on the different window designs for a master bedroom. Our bedroom is north facing and the bed will… 0 4559 1 15758 |
