Browse Forums Building A New House 1 Aug 08, 2010 10:44 am Hi All, Our prefered builder is recommending a concrete frame system (by Pegasus Prestige) for our new home rather than a traditional wooden frame. We have been told that concrete frames (a tilt system) is largely used in commercial construction and are only just now affordable on a residential level. The concrete walls are manufactured off-site and then erected on the block of land. We're a little hesitant as this is a new concept to us. Does anyone have any thoughts/feedback/information/comments? Many thanks PK Re: Concrete Frame 2Aug 08, 2010 10:57 am Yep... If done well they are up in weeks from just a sand pad and look just fine. Never need maintenance, everything is square.(or round as the case may be ) You just need to know that your design is not going to be compromised by solar gain/loss. Where you are coming from is where you are going to... This is 100% true. You can not hang anything on steel frames. very frustrating 8 8036 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28323 |
