Retaining, Paving and Stormwater - Southern Adelaide
Advice on who to call for the above.
We have about 26m of retaining wall that needs to be done. From 800mm-1000mm in height.
We have about 60m of perimeter paving including steps front and both sides.
We have a double driveway that needs paving.
We need a quote on our stormwater.
Thanks in advance
www.activestormwater.com they have been used by a few people, quick and prompt replies on quotes and such.
Why you changing builders, sounds all too familiar
They gave us a quote within 24 hours and out of 3 quotes were the cheapest for retaining walls (not sure if they do stormwater though)
Don't go with RWI they are a rip off.
We used Custom Built retaining walls intially, he did a good job, but was a bit of a rip off.
You should only be being charged about $130 a liner metre, anything more than that and you are being ripped off.
Luckily for me the guy who bought the block next door has decided to do all his own retaining walls (owner builder) We asked him to put in coloured sleepers (normally an extra $2.30 per sleeper) and he didn't charge us anything as we let him use our water and electricity. He was on the high side so had to pay full cost of the retaining wall.
I have a card somewhere here of this guy that of all the ones I have talked to has been the best, let me see if i can find it
I second your sentiments on RWI too, they were the most expensive for us by over $2k
3
Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know.
23/07/2023
3
Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know.
15/01/2024
1
in the stormwater pit or the drain? Those dont look like theyd fit in the drain. Separately, the pits do get stuff in them during the course of the build. For the most…
