Browse Forums Building A New House 1 Jul 31, 2010 5:44 pm Hi all, My neighbour believes my new slab is in the wrong spot. Basically the distance from slab to his wall is not what the dispensation drawings indicated. I don't believe the draftsman used a surveyor and took his own site measurements from neighbour’s house. The builder is saying that he laid the slab based on the boundary surveyor’s results to which he has indicated that the boundaries have moved - survey work came post council dispensation approval and neighbours sign off - The result is 15cm closer to the neighbour. Neighbour is not taking action yet, and may not; however I want to prepare myself as he is indicating an overshadowing problem. Any thoughts on this? Personaly I would have thought that when the builder new of the problem prior to laying the slab that he should have consulted me first or if the surveyor signing off the building permit should have picked up on the differnce between council approved dimensions versus the new boundary dimensions. Nervously yours, Steveo * Are we there yet ? Demolition has come and gone ! yippeeee..hang on that was months ago !! come on Mr Builder, dig a hole at least Finaly ! Hole Dug ! well done darren 20/06/2010. Slab is down ! Framing is complete 20/10/2010 we are progressing like a snail on heat - excited and determined but very very slow Steveo Re: uh oh, is the slab in right position? 2Jul 31, 2010 6:15 pm Have a look at the problems the people below have. Best wishes. "Our build with JG King" I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17538 They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 5874 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10461 |
