What did you do around you house? Did you concrete?
On the other side will have grass and more crushed granite, not sure how the grass will work against the house though.
Ok let me get this rght, I thought you had to have concrete around your house to protect it from movement ets. is this not the case. Can you just have rocks or pebbles, and it is fine, cause it surely must be a lot cheaper to do that.
A simple slab/pathway poured around the house will do nothing for movement. It's just easier to maintain in my opinion.
Most houses in SA would have a footpath around either concrete or paving have not seen any with pebbles or turf - but again most would be on clay
Damn. Our house doesnt have any concrete around it at all. When l went to the display homes they all used white pebbles around the house. l was trying to work out if l did this and did not have concrete then how am l gonna wheel the bin from the back of the house to the front on garbage collection day. Thats why l was confused as to what people normally do. would you get the concrete to slope away from the house so the rain doesnt slope towards the house or do you just make it flat?
You can always have pebbles with a narrow pathway down the middle. This way you get drainage, good appearance and can still wheel the bin around.
i'd love concrete, although we won't be able to have it as it offends the maximum ratio for hard surfaces, so we will be doing pebbles instead.
Even a 200 mm concrete edge will provide quite a bit of protection.
I'm having to think about this at the moment. I've got a face brick exteiror and I'm worried about the first few courses getting dirty from soil being splashed. So, the chouices I see are:
1) Put a penetrating sealer on the lowest three courses
2) Put white pebbles up agains the house (with plastic beneath to ensure that dirt doesn;t get spalshed on the wall)
3) A small (200 to 300 mm) concrete edge to provide runoff and stop spalshing.
Not sure what to do yet. Maybe it will happen a few years after the house is finished.
http://www.clarkrubber.com.au/matting-a ... tiles.html
Has anyone tried them for outdoor use?? Not sure what they are worth price wise though.
3
Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know.
2/05/2023
1
You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would…
20/12/2023
4
Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser…
