Browse Forums Building A New House 1 Jul 28, 2010 2:38 pm I really like a couple of light fixtures from beacon that are indoor lights and was wondering if I can install them outside? (Under the alfresco over the table, under cover) The women at beacon didnt know and just said 'they wouldnt be covered by warranty if they were outside (which doesnt bother my, its only $150) but im more concerned safety wise if it would be a problem or not? So if your an electrician, is this ok? I know anyone would probably just do it but Id like some other opionions, even if others have installed an 'interior' light fitting under your alfresco Why cant they make super nice alfresco lights?! Re: any electricians out there? Question??? 2Jul 29, 2010 11:59 am Can you pop up a picture of the fitting in question? There are several things that I would be concerned about (i'm not a sparky) like corrosion/rust. But with it being under a fixed roof alfresco area, so long as it was out of all but the worst weather, it should not be a problem. Some people don't have time to do the job right the first time, but seem to have plenty of time to fix their mistakes. Build Thread Re: any electricians out there? Question??? 3Jul 29, 2010 7:01 pm not sure how to post a link, but these are the 2 im thinking http://www.beaconshop.com.au/components ... 010821.jpg http://www.beaconshop.com.au/components ... 010862.jpg Re: any electricians out there? Question??? 4Jul 29, 2010 8:46 pm only real problem is if you don't want them swinging aroun din the wind.... hence my most out door lights are fixed to the roof/ walls... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal 4 14311 Unless there is something in special conditions the builder does not have to give you timeline. If your demolition contractor has not removed Asbestos and it was found… 12 28812 Thanks for the informative response! I'll feed that back to the site supervisor. 2 4130 |
