Browse Forums Building A New House 1 Jul 26, 2010 11:34 pm My builder has currently completed sealing all windows on the inside and painting is now complete. I have concerns regarding the gap under the window architrave being too big as I remember some were larger than others. During an inspection today, I applied a bit of pressure on the plaster near the edges of the window (to the suspect windows) and to my shock horror, the sealant has cracked in the join. It appears the plaster is moving and there's no support for the plaster under the architrave. I don't think this is acceptable despite the CS saying it is and the gap 'should have' been closed prior to fitting the architrave and they're not going to remove it to check. He was quite hesitant to do this. How am I supposed to know whether they've closed the gap? How's this for a fair bet: I even saw a small gap before they sealed and painted the join. Has anyone else had the same issues and did you get the builder to fix? http://newhousemapleslaurimar.blogspot.com/2010/07/painting-complete.html Building in the Maples, Laurimar. Follow our blog at http://newhousemapleslaurimar.blogspot.com Currently nearing completion Re: Plaster to window gap appears too big under architrave 2Jul 27, 2010 7:08 am I can't quite see the problem. The purpose of the architrave is to cover the area between the plaster and the window reveal. The frame opening should be 20mm bigger than the window reveal, so there will be always be a gap. I don't see any packers between the reveal and these should be there to meet best practice. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Plaster to window gap appears too big under architrave 3Jul 27, 2010 11:15 am Thanks Ed, Maybe no packers were fitted prior to the gap being covered up and this may be the cause of the plaster/architrave join cracks. All other window/plaster joins I've checked do not crack the silicone under light pressure so they havn't done it correctly. Well I guess no final payment until these are fixed. Building in the Maples, Laurimar. Follow our blog at http://newhousemapleslaurimar.blogspot.com Currently nearing completion Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10160 Got my stairs designed like this with 250mm Gap marked below. Gap is bec of 2 steps added between two landing area… 0 4878 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 19254 |
