Here are some update and questions. One of my prospective builders included clause "if site classification is worse than H or if piering is required then additional cost would apply". The builder said that soil classification from the government might not 100% accurate because it is base on sampling tests. The builder said that this clause is to cover himself if the "real" soil classification turn out to be worse. This is usually for "original" soil classification M and S.
Here are some other comments from the builder
1) that painted particle board for linen is better than the melamine one
2) price for linkware "sabine/kirra/mode" tapware is "similar" to the hansa polo. I thought hansa polo is up market?
3) colorbond watertank is better than poly tank
3) acrylic and polymarble for moulded top for vanity is durable, comparable with ceramic.
Could you please also comment if a quote 245,000 is this acceptable to build a house with the following spec?
1) Living area 174sqm, Porch 2.5sqm, Alfresco 11.5sqm, Garage 38.7sqm, and TOTAL (GFA) is 226.7Sqm. Soil classification is H and will use waffle pod.
2) brivis HE ducted heating, brivis counter evaporative, ducted vacuum+vac-pan, security system; BOSCH 26E continuous gas hot water with recess box
3) Ceiling height 2400
4) aluminium improved windows with flysreen.
5) CFL GU10 Downlights in living, standard batten, Electrical as per plan
7) kitchen allw $10,000 (to include (caesar stone)
9) Kleenmaid kitchen. cooktop CH711XFF, Rangehood RH5x, Bench oven TO901X
10) Vanities Marquis Premier with Nova, imperial, royal
11) nylex greywater diverter, one skylight, sealsealing tastic and exhaust
12) 4500 lt water tank with all connection and first flush.
13) two phone point, two tv points, 3 double points in living areas
14) Boral concrete tiles, PGH brick
15) Metal fascia, quad gutters, downpipes Colorbond
16) 75mm scotia cornices
17) LOCK: lockwood symmetry/nexion dead latch, meridion range.
Another quote is about $4,000 cheaper!
Thanks
Thanks.
