Browse Forums Building A New House 1 Jul 09, 2010 6:18 pm hi all, just wondering if we (my partner & I) should be concerned after noticing a crack on the concrete house slab (hairline) which runs from a bedroom into the main lounge dining area of our current house which we are building. The house slab was layed in March and we are a month off completion/final inspection. The carpet layers have not been in as of yet hence how we saw the crack. The main lounge dining area has been layed with ceremic floor tiles already. Any help on what to do would be greatly appriciated. Re: crack in house slab noticed 2Jul 09, 2010 7:57 pm I don't know where you are located or anything but I had a crack in my slab that ran from bathroom, across the hallway finishing up about the island bench. When I mentioned it to my SS he said unless they are wider then 5mm it is just a surface crack and they will not do anything about it. My point is give your SS a call and mention it, before the carpet gets laid so he can actually see it. My personal theory is that it is possibly just above the water pipe that runs from bathroom to sink in island bench (as it is more or less a straight line) but I don't know how true that that is. I have been living in the house for 5 months and the crack has not gotten any wider or longer in that time so I don't think it will be an issue for me. My tiles are going down this weekend so no one will be able to see it after then anyway. YAY Built with RedInk Custom 5000 Key Handover 15/12/2009 Re: crack in house slab noticed 3Jul 09, 2010 9:02 pm ref_kt When I mentioned it to my SS he said unless they are wider then 5mm it is just a surface crack and they will not do anything about it. A 4 mm crack in a slab would be a disaster!!!! Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: crack in house slab noticed 4Jul 09, 2010 9:29 pm The Guide to Standards and Tolerances 2007 (Building Commission VIC) indicates that slab cracks greater than 2mm are defects. Hairline cracks <.3mm are insignificant. Anywhere in between should be monitored for a year. Re: crack in house slab noticed 5Jul 09, 2010 9:29 pm We have several hairline cracks in our garage slab, which I'm not worried about, and also some in our driveway, again not a concern. There is one particular crack in our driveway that is an issue however. Even though we have been in our house for 21 months we had the maintenance guy here yesterday (he's new - and fantastic) finally finishing off some minor stuff (door latch adjustments etc) but the main reason we wanted him here was to monitor the widest crack in the driveway. He has taken photos for reference. His motto is that the crack is a concern if (1) you can stand a 20c coin in it, and (2) if, at the junction of two cracks, little 'islands' of concrete are created, like this: We are not overly concerned at this stage, at least officially our builder now has a reference to go by. Ouir driveway was included in the contract. Geoff - Decophile. Re: crack in house slab noticed 6Jul 09, 2010 9:35 pm Trinity The Guide to Standards and Tolerances 2007 (Building Commission VIC) indicates that slab cracks greater than 2mm are defects. Hairline cracks <.3mm are insignificant. Anywhere in between should be monitored for a year. Great info - in fact I just measured a 20c coin, and it appears to be very very close to 2mm thick! Geoff - Decophile. Re: crack in house slab noticed 8Jul 09, 2010 9:55 pm Eager We have several hairline cracks in our garage slab, which I'm not worried about, and also some in our driveway, again not a concern. There is one particular crack in our driveway that is an issue however. Even though we have been in our house for 21 months we had the maintenance guy here yesterday (he's new - and fantastic) finally finishing off some minor stuff (door latch adjustments etc) but the main reason we wanted him here was to monitor the widest crack in the driveway. He has taken photos for reference. His motto is that the crack is a concern if (1) you can stand a 20c coin in it, and (2) if, at the junction of two cracks, little 'islands' of concrete are created, like this: We are not overly concerned at this stage, at least officially our builder now has a reference to go by. Ouir driveway was included in the contract. I cant believe that the concretor who done that driveway couldnt have at least put expansion foam between the brickwork before the concrete was poured. It would have prevented it from cracking. Did they put saw cuts on the concrete? Because that also helps to eliminate cracks from occuring. If you want a job done properly... Do it yourself! Re: crack in house slab noticed 9Jul 09, 2010 10:13 pm Barwon374 I cant believe that the concretor who done that driveway couldnt have at least put expansion foam between the brickwork before the concrete was poured. It would have prevented it from cracking. Did they put saw cuts on the concrete? Because that also helps to eliminate cracks from occuring. The lack of foam was immediately noticed by the maintenance guy. There are plenty of saw cuts in the driveway, the largest hairline crack runs diagonally across one of the sections, corner to corner.... Geoff - Decophile. Re: crack in house slab noticed 10Dec 29, 2012 11:30 pm Eager We have several hairline cracks in our garage slab, which I'm not worried about, and also some in our driveway, again not a concern. There is one particular crack in our driveway that is an issue however. Even though we have been in our house for 21 months we had the maintenance guy here yesterday (he's new - and fantastic) finally finishing off some minor stuff (door latch adjustments etc) but the main reason we wanted him here was to monitor the widest crack in the driveway. He has taken photos for reference. His motto is that the crack is a concern if (1) you can stand a 20c coin in it, and (2) if, at the junction of two cracks, little 'islands' of concrete are created, like this: We are not overly concerned at this stage, at least officially our builder now has a reference to go by. Ouir driveway was included in the contract. Hey Eager, how did you or your builder resolve this? I'm having the same issue as well. Re: crack in house slab noticed 11Dec 30, 2012 7:04 pm No, the cracking never got any worse so we didn't bother making an issue about it. Geoff - Decophile. Most likely poor foam installation and render installation, Joint covered with render, foam could be sitting on flashing. Do you have any render at house 4 9413 13 6671 Petercurtis You able to contact the certifier and get a copy of your structural plans, if they are not in your contract. If your home was approved via CDC then they… 1 20187 |
