Browse Forums Building A New House 1 Jul 06, 2010 5:40 pm Hi We have optus cable running on our street. We wish to take optus underground connection. On our tender we have said ok for telstra underground connection. Now I would like to know do we have to have telstra underground connection if we are going to get optus undergrond connection. Has anyone not taken telstra underground connection? Has anyone used optus underground connection for their new house? Is this possible? Thanks Re: New Optus Connection 2Jul 06, 2010 8:51 pm Yellow, It would be a good idea if you specify where you are located as alot of new housing estates only use Telstra. As you have said that you want to go with Optus instead, you may need to contact your builder and see if they can change it for you. Hope this helps Re: New Optus Connection 3Jul 06, 2010 10:16 pm Telstra only do underground for new builds... that is for FTTH estates or Normal streets/ estates.. as for the Optus cabling.. you will need to have a seperate conduit for them but most likey will be done after hand over... if they can do it... at all... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal 3 48371 Hi all I'm currently building a duplex in Sydney and we need to do a new water connection to the second unit. The water main is on the other side of the road so we need… 0 4266 |
