How much of a problem is this? Does anyone know if it can be fixed?
Browse Forums Building A New House Re: Crumbling Slab 2Jul 03, 2010 7:00 pm Hi Melly, I am guessing the spall has occured due to the dynabolt being installed before the concrete has had time to cure enough. I suggest they should remove the dynabolt, clean away the spall, put some kind of priming agent on piece of slab to be repaired and repair it with a high strength quick curing repair mortar. They should leave it a set amount of time and redrill the hole for the dynabolt and put the bolt back in. Not a major issue, as it can be fixed Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16184 4 6209 The concreter will take and reuse. In my case I bought structural LVLs and scraped them back and used them as joists. 1 5180 |
