Browse Forums Building A New House Re: Ceiling insulation 2Oct 23, 2007 10:14 am Fibreglass ones can irritate the skin when you install it yourself. Cellulose/polyester or whatever they're made of don't make you itchy.
Rating 4.0 is the same meaning thermal properties are the same for both products. Not that you could ever tell the difference. Re: Ceiling insulation 4Oct 23, 2007 11:49 am ![]() What type of insulation is best (price, healthy)? Glasswool and rockwool batts/blankets Natural wool Cellulose fibre Polyester I have just read that Cellulose fibre is dusty and can settle. Glasswool batts - can be itchy and can irritate lungs if you inhale fibres. Wear a mask when installing. Wool - don't know much about it, but I daresay more expensive? Fibre - Blown in? Will settle. May get uneven coverage. Polyester - Easy to install, wont make you itch. Harder to cut than fibreglass along the length of batt. Not that you have to cut a lot. Similar price to fibreglass from memory or perhaps a tad more. Are you doing it or someone else? If yourself, I would use polyester batts cos they are fairly user friendly. And you need to eat about a bag and a half before they become dangerous. ![]() Ring around and get prices. Then decide. It's not a hard job but it's hot in the roof space. And getting batts up there is a bit of a pain in an existing house. And look here. http://www.choice.com.au/viewArticle.aspx?id=105246&catId=100519&tid=100008&p=3&title=Buying+guide%3a+Home+insulation 3 3060 Yes, you have a thermal bridge there which needs to be insulated in one way or another. I would simply glue some R2.5 batts there, you should be able to fit them. 2 1527 Yes, this is a huge thermal bridge which will more or less undermining the insulation already installed in the walls. Cold air will be travelling down from your under… 1 2641 |
