Browse Forums Building A New House 1 Jun 19, 2010 12:34 pm Hi there, I'm looking at some plans for a house with a 310mm freeboard waffle slab. I'm seeking clarification as to whether the slab for the single garage is the same thickness? The garage is attached to the house. Also, before the slab is laid, is there normally a layer of road base added and how thick is this normally? The cut and level for the house has been completed so what I'm trying to ascertain is how high above the fence the house will sit. Thanks for your help! isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17399 13 6564 Petercurtis You able to contact the certifier and get a copy of your structural plans, if they are not in your contract. If your home was approved via CDC then they… 1 19175 |
