Browse Forums Building A New House Re: Plastic plumbing pipe, and termite control barrier 2Jun 18, 2010 9:10 am as far as termite control goes, it depends on your situation. I guess from a consumer point of view that Termimesh is the best for slab penetrations as it does not require any maintenance. For perimeter protection, The White Ant Company are probably the best as they have a 15 year warranty period with no annual inspections required (almost all others require an annual inspection). Also consider building with T2 timber for your frames. Provided it is not cut on site, it is a very good repellant when used in conjunction with a perimiter guard termite barrier. "I never learned a thing until I finished school" - Unknown "You can get anything accomplished, If you don't mind who gets the credit" - Ned Hay 4 1892 DIY, Home Maintenance & Repair 3 pipes are coming from upstairs bathroom. 40mm from bathroom sink, 50mm from shower and another 50mm from the bathtub. Highly unlikely that any of these will be open at… 2 869 Hi, I had a barrier reef pool installed less that 2 years ago and the gel coat is already fading. The colour is electric grey shimmer which isn’t available… 0 3832 |
