Browse Forums Building A New House 1 Jun 15, 2010 7:52 pm Hi.. Need a little help we are looking at fridges however I have no idea how to read the plans to see available space for the fridge!! Any body who is building the Columbia 211 by Dennis Family Home, please help!! Laney Our Build Thread: viewtopic.php?f=31&t=30685 Re: how to read refrigerator space on plans??? 2Jun 15, 2010 9:04 pm look at the cavity distance, then subtract approx 15mm each side for plasterboard. also from the rear to the front. The fridge should have about 10mm min each side and you will need about 50mm rear clearance. Re: how to read refrigerator space on plans??? 3Jun 15, 2010 9:14 pm Do you have a 1:100 printout of your plans? Use your ruler. Not 100% accurate but it's going to give you a more accurate idea. For example mine is 1040 between the walls. Using my ruler I get 1cm, excluding skirting which is 20mm both sides. So I have 1m clearance and will fit a 980 width fridge. Re: how to read refrigerator space on plans??? 4Jun 15, 2010 9:25 pm Did you get specific kitchen plans with your plans or just the floorplan? Our space is ordinary (950 width 650 depth) have a small fridge tho. Or yeh... check the plans for a scale to go by and 1:100 = 1cm is 1m Built with New Generation (Summit Homes) We own land!... with a slab on it! Plus a shell of a house with stuff inside ! You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9959 Cupcake.girl This really depends on your local council. Each one has different definitions and ways to calculate contributions. This is called a contribution… 1 3582 dimensions on your original plan are inconsistent and with accurate dimensions (including site plan, upstairs and down) i could make a proper scale drawing with furniture… 3 7516 |
