Browse Forums Building A New House 1 Jun 15, 2010 4:38 pm We're trying to decide between stamped concrete and exposed aggregate. Has anyone got someone they can recommend? How do we see samples etc? Would the guy have a photo album etc or what happens? Thanks Life is; then you tell yourself a story. Re: Recommend A Driveway Concreter around Doreen? 3Jun 16, 2010 10:31 am I have seen some posts on here re exp agg colours etc and I know a few people suggested you look at midway mix, I think they are in sunshine, they apparently have different exp agg colours on show. As for stamped I am sure if you ring a couple of people out of yellow pages or local paper some would have brochure or website addresses you could have a look at. Hope this helps Site Start: 10th September, 2010 PCI : Friday 27th January, 2011. Handover: 3rd February, 2011 Build Thread: viewtopic.php?f=31&t=37677 Re: Recommend A Driveway Concreter around Doreen? 4Jun 16, 2010 11:39 am Our exposed was done by a mate who is no longer in the conrcete business btu we got our mix from Mentone Pre Mix. they have them all on their website and if you ring them the will gove you addresses to go look at certain mixes to make up your mind. 2nd build here we come in Whittlesea! https://forum.homeone.com.au/viewtopic.php?f=31&t=92617 1st Build - Henley - Cooper in Doreen! (2009) https://forum.homeone.com.au/viewtopic.php?f=31&t=17354 Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 11006 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7089 |
