Browse Forums Building A New House 1 Jun 15, 2010 4:31 pm Our builder hasn't put plaster around the rear garage door leading to the backyard. Does anyone know why this is? Our SS said they now do this so that moisture does not damage the plaster around the door as it's not waterproof. Is this a cop out? Cheaper for them? Should we insist on plaster around the garage door? Or is it better not being done? Just noticed it's not around the main electric garage door too. Life is; then you tell yourself a story. Re: Plaster around rear garage door 2Jun 15, 2010 5:42 pm If I think I know what your talking about we dont have plaster there either. There is about one brick that is not covered around our door either we didn't ask why we just presumed there was a reason for it Re: Plaster around rear garage door 3Jun 15, 2010 5:47 pm Our builder has completely plastered around ours. Have a drive around the new estates, and check out more builds that are near completion (they usually dont have a garage door yet, so you can see in). It sounds like your builder is cutting costs...? Actually, PM Lisanne... I cant picture hers... but I'm sure it's plastered Re: Plaster around rear garage door 4Jun 15, 2010 6:17 pm Just looked at Lisa's photos and we too are building with pd so that is something I might bring up at pci on friday Re: Plaster around rear garage door 5Jun 15, 2010 7:42 pm No plaster around our rear door.... The back wall is plastered but that stops just before the door frame and has a metal thingie (technical term ) to finish it off neatly. The side boundary wall has no plaster either, nor does the front. Only the sections of wall that are shared internal walls with other rooms are plastered. Some garages have plaster all through, but I'm not really sure why that is. The ones I've seen are mostly set back from the boundary, ours is built right on the boundary - I have no idea if that makes any difference at all. But anyway, as long as the brickwork is cleaned and neat, I don't see a problem. It's only a garage. Re: Plaster around rear garage door 6Jun 15, 2010 7:48 pm In our last house the only plaster was on the walls that were shared with the house interior-so they were framed stud walls-not brick. The rental we are in now is the same. Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Plaster around rear garage door 7Jun 16, 2010 8:59 am Thanks everyone. I saw Lisa's photos and she has plaster all the way around. No idea why some have it and others don't. Guess it will remain a mystery. True Kek, it is just a garage, I was just curious because it looked funny but luckily we love our bricks so I won't worry. Life is; then you tell yourself a story. If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8331 Screed is installed before or after, what was not up to code? You have 4x images, door frame, The work is poorly applied rough, with no care for how it should be done, if… 5 2682 |
