Browse Forums Building A New House 1 Jun 14, 2010 8:59 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi, We have a big gap above the rear door in the garage? Will the builder be able to fix it? Please give me some comments. I am worried the builder would say it is normal and not going to fix it... Regards, Kin Metricon Amira Re: Big gap above the rear door in garage 2Jun 14, 2010 9:02 pm Sorry, hate to say it but this does not seem right........would be interested what the builder says they can do.........weather seal might do it........not sure as it looks like a large gap though........ Contact them immediately............. Signed with Carlisle - Atlantique 36Mk2 altered & upsized Botanic Ridge Estate - Build started 22nd Oct 2010 Re: Big gap above the rear door in garage 4Jun 14, 2010 9:46 pm Definitely doesn't seem right, and looks like something that could cause issues moving forward. Stefan Building the M3tr!con Liberty 42 at Stonecutters Ridge. The New Build Blog - "Life, In Progress." Stonecutters Ridge Community Website | My photos Re: Big gap above the rear door in garage 5Jun 14, 2010 9:51 pm kikin With such big gap, will it affect the structure of the house? I wouldnt worry about the gap, It has no structual bearing at all on that wall. All they will do is put urethane to fill the gap. hope this helps. If you want a job done properly... Do it yourself! Re: Big gap above the rear door in garage 6Jun 14, 2010 9:51 pm It looks as though it could be an articulation (or expansion) join. Check your plans and see if A/J is marked on them in that position. If it is, it should be filled with a coloured putty/silicone to match the bricks, but I'd be checking with your SS anyway....for piece of mind! I'm sure there are 'tolerances' for maximum widths of A/J's, but best to check with your builder/SS, to see if it's OK and 'acceptable' Henley - Wilshire Mk 3 ... I love my house!! Site start: 4th Feb 09 Handover: 10th Sep 09 Blog: http://stormygirlscastle.blogspot.com/ Build Thread: viewtopic.php?t=7166 Re: Big gap above the rear door in garage 7Jun 14, 2010 10:02 pm Stormy It looks as though it could be an articulation (or expansion) join. Check your plans and see if A/J is marked on them in that position. If it is, it should be filled with a coloured putty/silicone to match the bricks, but I'd be checking with your SS anyway....for piece of mind! I'm sure there are 'tolerances' for maximum widths of A/J's, but best to check with your builder/SS, to see if it's OK and 'acceptable' Thanks for your information. I just checked on my floor plan and found that the gap for A/J should be 10mm. Metricon Amira Re: Big gap above the rear door in garage 10Jun 19, 2010 2:31 pm I have been told by the building manager that it is an articulation join and it will be filled as stormy said.... By the way, our site supervisor has resigned and the new one will be replaced from next Monday.....hope it can go smooth.... Metricon Amira Re: Big gap above the rear door in garage 11Jun 19, 2010 3:33 pm I'd be measuring the gap at top and bottom to make sure it's within tolerances. Some brickies add the foam strips as they brick, but others don't and it gets shoved in at the end. Either is apparently fine (I looked it up when our brickwork was done). Then the goopey stuff goes in.... so the method isn't a problem, but the quality of the brickwork might be a whole other thing. One of our AJs was appalling - definitely NOT within tolerances: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The bricks around it had to be ripped down and redone weeks later, so it certainly can be done if the gap is outside normal tolerances. You can't tell the difference between the old and new brickwork now either. Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8541 Got my stairs designed like this with 250mm Gap marked below. Gap is bec of 2 steps added between two landing area… 0 4915 |
