Browse Forums Building A New House Re: Opinion Needed on Poor Mortar Work 21Oct 16, 2007 5:55 pm FG,
Could you have any more bad luck?? There are standards that need to be adhered to for the composition and application of mortar. Definatley get it tested by an independant inspector. It will be money well spent. Matt Re: Opinion Needed on Poor Mortar Work 22Oct 16, 2007 5:58 pm Spoke with the BACV, organising an inspection. Re: Opinion Needed on Poor Mortar Work 23Oct 16, 2007 9:37 pm I think Michelle is right, not enough cement in the mix and probably a bit too dry as well. It also looks like they have not laid enough mortar as well. When the brick is placed in position the excess mortar should ooze out the side, this is then trowelled off. It looks like the joint has then been rolled but there was not enough mortar to get a decent finish.
I'd make them tear it down and get someone who knows what there doing. Also given that it has cracked so quickly there is every chance that any render applied would also crack. Good luck !!! Re: Opinion Needed on Poor Mortar Work 24Oct 16, 2007 9:40 pm shanem I think Michelle is right, not enough cement in the mix and probably a bit too dry as well. It also looks like they have not laid enough mortar as well. When the brick is placed in position the excess mortar should ooze out the side, this is then trowelled off. It looks like the joint has then been rolled but there was not enough mortar to get a decent finish. I'd make them tear it down and get someone who knows what there doing. Also given that it has cracked so quickly there is every chance that any render applied would also crack. Good luck !!! Oooo I guess I’m not such a silly woman after all! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Opinion Needed on Poor Mortar Work 26Oct 16, 2007 9:46 pm Duracell Battery……that’s you Ash…..he just keeps going!
Or is that Ever-ready??? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Thanks for the suggestion. The space between shower and sinks was too tight. I agree about the toilet location. So I have tried two other options: The lower one is… 3 6144 these look like missing batts. Go up and take a look. But yeah moisure meter is a completely different tool 4 9460 Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.… 0 4582 |
