Browse Forums Building A New House 1 Jun 09, 2010 2:09 am Hi Plunkett put the roof tiles on, mystified as to the steps after this ? anyone know ? plastering ? windows ? hmm Davo Re: Roof Tiles On- Whats are the next phases ? 4Jun 09, 2010 4:04 pm I assume you have window frames? They should probably start the float for the plaster stage, or render the outside. The electrician and plumber should have been too, that will be next if they haven't. Built with New Generation (Summit Homes) We own land!... with a slab on it! Plus a shell of a house with stuff inside ! Re: Roof Tiles On- Whats are the next phases ? 5Jun 09, 2010 4:16 pm Candylea I assume you have window frames? They should probably start the float for the plaster stage, or render the outside. The electrician and plumber should have been too, that will be next if they haven't. Window frames in yes water,electrics,gas points in guess render/plaster yes hhmm i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16026 Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20191 Did you know that you can get rugs made from carpet? So much cheaper than buying a shop rug. So many styles to choose from, but you won't get the highly patterned… 0 6280 |
