Browse Forums Building A New House 1 Oct 16, 2007 11:35 am Hi Friends,
I got lot of support from the forum members before so I came back to hassle you again. I have purchased a block of land. Please visit http://kanchi7880.blogspot.com/ to check the situation of a lot I have purcahsed I contacted almost all major builders but any good design of those builders doesn’t fit in to block. I inquired a couple of local builder but they gave me quotation of $12000 - $13000 / sq which is too high compared to major builders. I want to build double story house and total area would be around 38 sq. Can anyone have any idea of builder having good price and plan to fit into a lot i mentioned here. Thanks to all in advance. Regards, KanChi Re: Looking for suggestions from experts 2Oct 16, 2007 12:45 pm Hey Kanchi - the issue with project builders is going to be the garage at the back - most project designs have the garage out the front.
I'd try going to new estates & display villages and look for houses that are on a corner - as what you're describing is often a covenant - main entry must be on major road, but garage access on the side. I'll keep an eye out for some designs. Re: Looking for suggestions from experts 3Oct 16, 2007 1:29 pm ![]() Hey Kanchi - the issue with project builders is going to be the garage at the back - most project designs have the garage out the front. I'd try going to new estates & display villages and look for houses that are on a corner - as what you're describing is often a covenant - main entry must be on major road, but garage access on the side. I'll keep an eye out for some designs. Thanks stonecutter ... I think I didn’t place enough information on diagram. Now I placed a new diagram here. Please check http://kanchi7880.blogspot.com/ Actually I want to make left side of my lot which is facing WEST as frontage ... as mentioned in diagram, because road on WEST is is a main road and also opposite to the Park. I can place a door facing WEST side; there is not restriction on it from land developer or council. As I personally believe it is good to place a door facing NORTH so I want to place it that way. I want to design a house so from outside it should looking facing WEST (Park Side) but door is not facing that way ... main entry is not facing that way ... Main Entry is facing NORTH. Another question is… why customer builder or project builder are costlier then major builders? There is almost $3000 to $5000 / sq difference between major builder and custom builder … does anyone know a reason for that? Does anyone know any custom builder have reasonable rate with same sort of quality which major builder has?? Thanks Re: Looking for suggestions from experts 4Oct 16, 2007 1:44 pm kanchi this is a great design:
http://www.henley.com.au/vic/?part=houses&home_id=17 and this one too (no north door though) http://porterdavis.com.au/#homeviewer/Windsor/47 Matt Those two designs are great but doesnt fit in my lot & s 5Oct 16, 2007 2:23 pm ![]() kanchi this is a great design: http://www.****.com.au/vic/?part=houses&home_id=17 and this one too (no north door though) http://porterdavis.com.au/#homeviewer/Windsor/47 Matt Hi Matt, Thanks for sending me those designs. I check them before but non of them is suitable for my block of land ... In Majestic... door is in correct position but garage is on the other side of the lot and if they flip the plan garage will come on correct position but then door direction change And Windsor is amazing ... but not suitable again same situation ... they don’t want to change a plan as per my requirement. At this stage I would like to find some design that can give me door on North side ... I made my own design which is reasonably good but couldn’t find any good builder to build it at major builder's price. If you come across any builder or any good design please keep posting me. For your information i finally purchased this block in The Chase @ Berwick. Thanks. Re: Looking for suggestions from experts 6Oct 16, 2007 2:25 pm Kanchi,
Delete the garage from the plan altogether. You could build it on the other side perhaps? Have you asked H3nl3y about it? Matt Re: Looking for suggestions from experts 7Oct 16, 2007 2:47 pm Just a short list below for you to check out....
http://www.**.com.au/ ... c/Builders http://www.gilpiphomes.com.au/ http://www.boutiquehomes.com.au/ Don't know if they will help, but a few to choose from.... May be you ask, "The Stig", ![]() ![]() Gav & Vanessa Building In Melbourne (Sth East Suburbs) http://www.arkraider.blogspot.com/ Rawdon Hill Construction - Canterbury Heritage But I will be provided with drive-away on that side of block 8Oct 16, 2007 4:52 pm ![]() Kanchi, Delete the garage from the plan altogether. You could build it on the other side perhaps? Have you asked H3nl3y about it? Matt But I will be provided with drive-away on that side of the block ... Can i still change it ?? Or can i ask them to provide me drive way on other side ?? What you think ?? Re: Looking for suggestions from experts 9Oct 16, 2007 6:58 pm From my experience with the Chase development if the crossover is not in yet then you can ask to have it wherever you like (within guidelines).
Even if the crossover is there you can apply to have another put in. I totally agree with everything you have written. Thanks again for your always excellent input and advice. I really enjoy reading your posts cheers Simeon 1 2763 ![]() Hi, Looking to add an ensuite to one of the bedrooms and make it a Master BR. Please see the attached current floorplan. Need suggestions on what's the best way to do… 0 4939 Suggestions please for acrylic rendering Color to match austral brick urban one pepper. Pic for reference. Thanks 0 1834 |
