Browse Forums Building A New House Re: Sealing plaster walls - oil based vs water based 2Jun 04, 2010 9:16 am Ok Lachjor, here's my 20 cents worth... 1. For new-set plaster, definitely an oil-based sealer/binder followed by an acrylic topcoat 2. For gypock walls and ceilings then an acrylic sealer undercoat made for wallboard followed by an acrylic topcoat will suffice. In my case I had some moisture damage to my gyprock ceiling so I used an oil-based sealer made by Zinser which covers the yellow stain. Generally, the acrylic paints are more flexible, faster drying and less toxic than the oils, but there are places where oil based paint is essential. I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying? 0 1921 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10970 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6700 |
