Browse Forums Building A New House Re: McDonald Jones Homes - The new thread 461Nov 14, 2010 8:30 pm Thanks Lizzie for your information. We put our 3K deposit yesterday, after going through the preliminary quote and adjusting some things. We have decided to go with tiles/timber frame (must be crazy) as we like tiles better. I thought I would delete the sarking ($2.7K extra cost) and go with light coloured tiled roof. I've read about the extra 3K for anticon, so that was another thing to make us choose tiles. I posted this in another topic but only got one reply and would like to know if anyone has any thoughts on the following quotes? "I 've been searching everywhere to find out the avarage cost to these two requirements, could not find much. My block of land is affected by salinity most likely and builder has included " Your attention is drawn to the 'Building in Salinity Prone Environment' policy bu council"-$3740...I thought this can vary depending on the level of salinity effect (low, moderate, high etc..) and what extra things need to be done depending on this. Did anyone have this in their quote or knows more about this? Also have this cost: 'Provide PVC downpipes % upgrade stormwater to 100mm (sewer grade) for chaarged downpipe system. Provide aboveground slimline water thank on a concrete slab. Flush out point is provided before the tank. Recycled water will be to toilets, washing machine and one external tap. No allowance for tunnel or rubble trench for overflow. $7990-THIS SEEMS A BIT HIGH-What do you think?? To connect tank overflow from tank water to rear inter-allotment drainage. $1660???" Lizzie, I will contact Austral to check the categories out, thanks for the tip, I actually thought I would drive up to Horsley Park as not too far away. I like the colours of Sanorini display on the Central Coast ( from the photos only on the MDJ website, have not been up there), if anyone knows brick/roof colours, if you could please let me know... I hope I learn more along the way. taki Building Havana Elite with side HT with MJD 20/04/11 DA approved by council 06/06/11 cut/fill 08/06/11 piering 20/6/11 slab 11/8/11 frame complete 18/9/11 lock up 28/11/11 handover booked Re: McDonald Jones Homes - The new thread 462Nov 15, 2010 10:41 am taki Thanks Lizzie for your information. We put our 3K deposit yesterday, after going through the preliminary quote and adjusting some things. We have decided to go with tiles/timber frame (must be crazy) as we like tiles better. I thought I would delete the sarking ($2.7K extra cost) and go with light coloured tiled roof. I've read about the extra 3K for anticon, so that was another thing to make us choose tiles. I posted this in another topic but only got one reply and would like to know if anyone has any thoughts on the following quotes? "I 've been searching everywhere to find out the avarage cost to these two requirements, could not find much. My block of land is affected by salinity most likely and builder has included " Your attention is drawn to the 'Building in Salinity Prone Environment' policy bu council"-$3740...I thought this can vary depending on the level of salinity effect (low, moderate, high etc..) and what extra things need to be done depending on this. Did anyone have this in their quote or knows more about this? Also have this cost: 'Provide PVC downpipes % upgrade stormwater to 100mm (sewer grade) for chaarged downpipe system. Provide aboveground slimline water thank on a concrete slab. Flush out point is provided before the tank. Recycled water will be to toilets, washing machine and one external tap. No allowance for tunnel or rubble trench for overflow. $7990-THIS SEEMS A BIT HIGH-What do you think?? To connect tank overflow from tank water to rear inter-allotment drainage. $1660???" Lizzie, I will contact Austral to check the categories out, thanks for the tip, I actually thought I would drive up to Horsley Park as not too far away. I like the colours of Sanorini display on the Central Coast ( from the photos only on the MDJ website, have not been up there), if anyone knows brick/roof colours, if you could please let me know... I hope I learn more along the way. taki Taki I can only comment on the PVC downpipes, stormwater & tanks etc. Basically all the same wording in our tender except we need a 10000 litre water tank. Cost $8100. Overflow is to a detention system. Cost $1940. The internal pump, rainsaver device & controller is included in the price. Hope this helps Re: McDonald Jones Homes - The new thread 463Nov 15, 2010 11:15 am muscovy taki Thanks Lizzie for your information. We put our 3K deposit yesterday, after going through the preliminary quote and adjusting some things. We have decided to go with tiles/timber frame (must be crazy) as we like tiles better. I thought I would delete the sarking ($2.7K extra cost) and go with light coloured tiled roof. I've read about the extra 3K for anticon, so that was another thing to make us choose tiles. I posted this in another topic but only got one reply and would like to know if anyone has any thoughts on the following quotes? "I 've been searching everywhere to find out the avarage cost to these two requirements, could not find much. My block of land is affected by salinity most likely and builder has included " Your attention is drawn to the 'Building in Salinity Prone Environment' policy bu council"-$3740...I thought this can vary depending on the level of salinity effect (low, moderate, high etc..) and what extra things need to be done depending on this. Did anyone have this in their quote or knows more about this? Also have this cost: 'Provide PVC downpipes % upgrade stormwater to 100mm (sewer grade) for chaarged downpipe system. Provide aboveground slimline water thank on a concrete slab. Flush out point is provided before the tank. Recycled water will be to toilets, washing machine and one external tap. No allowance for tunnel or rubble trench for overflow. $7990-THIS SEEMS A BIT HIGH-What do you think?? To connect tank overflow from tank water to rear inter-allotment drainage. $1660???" Lizzie, I will contact Austral to check the categories out, thanks for the tip, I actually thought I would drive up to Horsley Park as not too far away. I like the colours of Sanorini display on the Central Coast ( from the photos only on the MDJ website, have not been up there), if anyone knows brick/roof colours, if you could please let me know... I hope I learn more along the way. taki Taki I can only comment on the PVC downpipes, stormwater & tanks etc. Basically all the same wording in our tender except we need a 10000 litre water tank. Cost $8100. Overflow is to a detention system. Cost $1940. The internal pump, rainsaver device & controller is included in the price. Hope this helps Muscovy, What is your tank made from? Re: McDonald Jones Homes - The new thread 464Nov 15, 2010 1:26 pm b.lizzie muscovy taki Thanks Lizzie for your information. We put our 3K deposit yesterday, after going through the preliminary quote and adjusting some things. We have decided to go with tiles/timber frame (must be crazy) as we like tiles better. I thought I would delete the sarking ($2.7K extra cost) and go with light coloured tiled roof. I've read about the extra 3K for anticon, so that was another thing to make us choose tiles. I posted this in another topic but only got one reply and would like to know if anyone has any thoughts on the following quotes? "I 've been searching everywhere to find out the avarage cost to these two requirements, could not find much. My block of land is affected by salinity most likely and builder has included " Your attention is drawn to the 'Building in Salinity Prone Environment' policy bu council"-$3740...I thought this can vary depending on the level of salinity effect (low, moderate, high etc..) and what extra things need to be done depending on this. Did anyone have this in their quote or knows more about this? Also have this cost: 'Provide PVC downpipes % upgrade stormwater to 100mm (sewer grade) for chaarged downpipe system. Provide aboveground slimline water thank on a concrete slab. Flush out point is provided before the tank. Recycled water will be to toilets, washing machine and one external tap. No allowance for tunnel or rubble trench for overflow. $7990-THIS SEEMS A BIT HIGH-What do you think?? To connect tank overflow from tank water to rear inter-allotment drainage. $1660???" Lizzie, I will contact Austral to check the categories out, thanks for the tip, I actually thought I would drive up to Horsley Park as not too far away. I like the colours of Sanorini display on the Central Coast ( from the photos only on the MDJ website, have not been up there), if anyone knows brick/roof colours, if you could please let me know... I hope I learn more along the way. taki Taki I can only comment on the PVC downpipes, stormwater & tanks etc. Basically all the same wording in our tender except we need a 10000 litre water tank. Cost $8100. Overflow is to a detention system. Cost $1940. The internal pump, rainsaver device & controller is included in the price. Hope this helps Muscovy, What is your tank made from? Re: McDonald Jones Homes - The new thread 465Nov 15, 2010 3:56 pm Hi, Thank you all for your response. I thought the quote for water tank and connection is fairly high and that is the part that surprised me the most. I'm still trying to find out if this is a rip off or not. Also, I asked the the sales rep about deleting the sarking, but it was recommended to me not to do this. Still reading more about it. Have you all decided to include this item? Could anyone share the cost of raising the ceiling to 2550, mine is $4500 standard home + $720 additional for altered home. I'm sure I'll have many more questions along the way, I'm proving not to be an easy customer. Cheers, taki Building Havana Elite with side HT with MJD 20/04/11 DA approved by council 06/06/11 cut/fill 08/06/11 piering 20/6/11 slab 11/8/11 frame complete 18/9/11 lock up 28/11/11 handover booked Re: McDonald Jones Homes - The new thread 466Nov 15, 2010 4:38 pm taki Hi, Thank you all for your response. I thought the quote for water tank and connection is fairly high and that is the part that surprised me the most. I'm still trying to find out if this is a rip off or not. Also, I asked the the sales rep about deleting the sarking, but it was recommended to me not to do this. Still reading more about it. Have you all decided to include this item? Could anyone share the cost of raising the ceiling to 2550, mine is $4500 standard home + $720 additional for altered home. I'm sure I'll have many more questions along the way, I'm proving not to be an easy customer. Cheers, taki Hey taki, Our costs for raising the ceiling are pretty much the same with Standard quoted as $4330.00 and Altered $680.00 and that was before they were going to rise their prices. Also in regards to the downpipes,stormwater $8270.00 and connection for the tank overflow $1290.00. Has anyone had to get an engineer draw up a plan for a proposed retaining wall? Like us both the engineer and the council were somewhat suprised that MJ didn't provide this so another $500.00 to add to the list. Building The Monte Carlo with PR-MJ Re: McDonald Jones Homes - The new thread 467Nov 15, 2010 5:09 pm Hi taki & jacko8317 The tank is only gold plated I think. Seriously I think it is poly/plastic. I received a separate quote from a local supplier for a 10000 litre tank, pump,controller + limiting valve, $2695 delivered. Of course this does not include concrete stand, fittings & labour etc. It's all part of the BASIX Re: McDonald Jones Homes - The new thread 468Nov 17, 2010 11:53 am Hi Woodduck, I noticed in one of your previous posts that you are getting porceline tiles laid by MJH. Do they do this after all the painting and electrical fitout so that they will not get damaged by other workmen? We have put tiling in our tender and are a bit worried how it will turn out. Re: McDonald Jones Homes - The new thread 469Nov 17, 2010 12:57 pm 1155 Hi Woodduck, I noticed in one of your previous posts that you are getting porceline tiles laid by MJH. Do they do this after all the painting and electrical fitout so that they will not get damaged by other workmen? We have put tiling in our tender and are a bit worried how it will turn out. Yes, we are getting MJH to do all our floors, painting finished last friday, plumbers finishing off today, aircond going in today. fix off to follow and i believe the tiles will be laid next week after these trades finish. Then the carpet to follow. So hopefully it shouldnt get damaged. Will keep you posted. Woodduck Building The Chesterfield Grande with McDonald Jones https://forum.homeone.com.au/viewtopic.php?f=31&t=33587 Re: McDonald Jones Homes - The new thread 470Nov 18, 2010 9:21 am gavmer1 Hey all, Updated my blog with a couple pics of land and plans. The snag continues and im told of a resolution today - full amount cant be put in security account as half of it is in term deposit making good interest. Ive left it to them so lets see what they do as it could make or break me here. Gav Hi Gavmer Did you manage to overcome the term deposit problem and what was MJH's resolution. I'm in the same predicament. Thanks Muscovy Re: McDonald Jones Homes - The new thread 471Nov 18, 2010 9:00 pm We've been told that we will be in by xmas. Totally unexpected but exciting!! so much planning to do now. Apparently our SS will have an exact date by the end of next week.. Building with McDonald Jones - Bordeaux 14m @ the ponds in sydney's north-west Build Blog => http://damianandannasabode.blogspot.com/ Construction status - DONE. Re: McDonald Jones Homes - The new thread 472Nov 19, 2010 6:24 am danana We've been told that we will be in by xmas. Totally unexpected but exciting!! so much planning to do now. Apparently our SS will have an exact date by the end of next week.. We've been told the same, but no one will give us a date so we can organize everything. Good luck everyone! Building The Chesterfield Grande with McDonald Jones https://forum.homeone.com.au/viewtopic.php?f=31&t=33587 Re: McDonald Jones Homes - The new thread 473Nov 19, 2010 7:56 am Hi Folks, Finally some action on our block, piers were done yesterday and it only cost us an extra $312, yay! we were a bit worried that it was going to be a lot extra than that so we're happy now that we know definetly how much we are in for. interestingly, the extra ended up being for 2 extra piers to be put under the slab part for the watertank which hadn't been marked on the plans but we definetly needed. I'm glad someone picked that up! Now that things have started they appear to be on the ball, we are told we will have a slab early next week and a frame not far after that! Yipee!!!! Congratulations to those expected to be in by Christmas, I expect a very busy few weeks leading up to it though! Re: McDonald Jones Homes - The new thread 474Nov 19, 2010 8:56 am vpeewee Hi Folks, Finally some action on our block, piers were done yesterday and it only cost us an extra $312, yay! we were a bit worried that it was going to be a lot extra than that so we're happy now that we know definetly how much we are in for. interestingly, the extra ended up being for 2 extra piers to be put under the slab part for the watertank which hadn't been marked on the plans but we definetly needed. I'm glad someone picked that up! Now that things have started they appear to be on the ball, we are told we will have a slab early next week and a frame not far after that! Yipee!!!! Congratulations to those expected to be in by Christmas, I expect a very busy few weeks leading up to it though! Vpeewee, Thats great news, now you will see something different each time you visit, its all very exciting. We have our bricks finished and waiting for the roof to go on should see a roof by Monday. Riccathome.. Building:Bronte Grand Manor Re: McDonald Jones Homes - The new thread 475Nov 19, 2010 11:22 am Hi Muscvoy, MJH were pretty good and did what they could. At the end of the day though, the funds will be coming out of term deposit a little early and the bulk will be there as requested but, there have been a cople of concessions. They are definitely open to discussion and i would present your case to them to see what you can arrange. Hope it all goes well for you - this could have been the end for us but luckily, we are all systems go! Cheers! Gav Building the Monte Carlo with side activities in Mt Annan MY BLOG: http://gavsfirstbuild.blogspot.com/ Re: McDonald Jones Homes - The new thread 477Nov 19, 2010 8:57 pm Hi everyone Just a quick update to let you know we received our keys last week - our pre-handover walkthrough was painless, with some paint touchups, a missing dishwasher and the join in the stone countertop to be rectified, plus the Telstra connection to be organised. It took a week to get the keys, but it gave us time to organise ourselves and our "stuff". The house looks beautiful, we are really pleased with it, our new furniture is arriving bit by bit so it's a little easier than having everything arrive at once! Our shutters were installed yesterday, our driveway was laid and the fencing commenced, so it's looking like a home now instead of a construction site, especially since they took the pretty blue loo away. Council did a drive past to-day and issued our Occupancy Certificate, so it's all go! In case anybody has a similar problem with porcelain tiles - the tiler had marked them with pencil and I couldn't remove the marks, researched it on Google and the suggestion was to use a pencil rubber - it works!! Many thanks to MJH, our site supervisor, our customer service officer and the colour selections staff for their assistance over the past eleven months, we've been a bit of a pain with a few things but we've gotten there in the end. I hope you are all progressing well with your builds and for those that may be in for Xmas, best of luck and have fun. I have enjoyed reading your posts and even now we have "finished", I'll still log in to check out what's happening. EvyK Re: McDonald Jones Homes - The new thread 478Nov 20, 2010 4:12 pm We have had some progress this week despite the rain. The roof is now finished and we expect the electrical wiring to start on Monday. We should now not have to worry about the weather. Re: McDonald Jones Homes - The new thread 480Nov 21, 2010 7:11 am Hi Bee224, I suppose one tip is to be patient from now on, I think paperwork will go slowly. We went through prelim quote one by one with sales rep. Still changed some thing along the way, e.g. they quoted children's activity door as the most expensive one at $3.6 approx and we wanted a normal sliding/cavity door. Think it should be golden at that price. Anyway there is still room for change. I e-mailed back and forth with all thing I remebered after that intial deposit and always got a quick reponse. One tip would be to try and provide all relevant documents to the builder, those instruments 88B, 149 etc and chase your land developer for all documents they might have about your land (comnpaction report/Geotech)...and of course learn as much as you can so you show to the builder that you know stuff and they would hopefully be more on the ball. Good luck with your build. taki Building Havana Elite with side HT with MJD 20/04/11 DA approved by council 06/06/11 cut/fill 08/06/11 piering 20/6/11 slab 11/8/11 frame complete 18/9/11 lock up 28/11/11 handover booked Hi AKG, We had a base tender of $592 for 31 squares from MC Donald Jones. It looks relatively cheaper than other builders. But I assume there are many hidden things that… 1 16848 Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 11121 Hi there! Putting the feelers out there for those who have (or almost) built with Arli homes! Interested in your experiences who've built from their stock home designs… 0 23502 |
