BUILD HOUSE AT WYNDELLA ESTATE (SIMOND-FLINDERS-TYPE)
Anyone know which plan suit on my block ?
I have a land at wyndella estate truganina.
it's corner block which must have double garage.
the problem is :
the front width = 12.39M.
but because it's corner so it must be reduce by 2M
so maximum I can build only 10.39M
the driveway is infront.
Any Idea ?
I found simonds home has a flinders type
http://www.simonds.com.au/
It's good type but I have to trim it from right to 1.3M.
Isn't will be too small ?
Anyone have experience building with Simonds (Flinders Type).
Do you get rebate, if you trim the size ?
Is it a good idea to trim the original plan?
Do you have any suggestion/input ?
Thanks a lot for your help
Why dont you skim through the other websites and narrow down the search to a frontage size that you need. If it doesmt' work out, then you may have to get an independent builder.
Good luck!
or I have to choose other design.. ?
I found one.. which is in HomesNow Design..
But I saw a lot of reviews.. it seems they are *** on Site cost.
Is that better that I just do my custom plan on other builder such as arban ?
Is that so much expensive with similar design idea ?
Thanks
Natural stone tiles like slate, travertine, and limestone add a timeless, elegant look to…
