BUT !!!!!!
Do you think my downpipes and the piping to the strom water drains line up ???? No the piping to the strom drains are all off to the right by about 15 - 20 cm.
How hard is it to make them line up
Browse Forums Building A New House 1 Oct 11, 2007 10:17 pm Went to see how the roof and guttering was going today, nice surprise its all done and the elecrtical pre wiring is in
BUT !!!!!! Do you think my downpipes and the piping to the strom water drains line up ???? No the piping to the strom drains are all off to the right by about 15 - 20 cm. How hard is it to make them line up ![]() Building again . . with Redink Pre-start 04/12 Keys - 03/13 Finishing off. . . Painting/Floor Tiles/Carpet - 04/13 Walk In Robe/Lighting/Blinds and Moving 05/13 Gates/Front Landscaping / Pool 05/13 Re: Pipes that don't line up 3Oct 12, 2007 1:47 am It's done on purpose to keep them away from the slab when the slab is being laid. Soon enough your plumber will dig around the storm water outlets and will line them up properly. Currently Building in Bayside (Brighton East) Re: Pipes that don't line up 4Oct 13, 2007 12:46 am AH excellent so they arn't as silly as i thought they were ![]() Building again . . with Redink Pre-start 04/12 Keys - 03/13 Finishing off. . . Painting/Floor Tiles/Carpet - 04/13 Walk In Robe/Lighting/Blinds and Moving 05/13 Gates/Front Landscaping / Pool 05/13 It makes sense though. I can’t see any other purpose for the pipes in that location and all the neighbours have covered theirs. But I want to be sure before covering them. 2 3495 DIY, Home Maintenance & Repair I've gone under my house to see if I can find the cause of the high moisture in our home. While crawling around in the damp ground, I came across copper pipes and noticed… 0 2286 that's where your drains should be. the plumber is usually supposed to chop them down to ground level at the end, and cap it with some sort of a grill, like the one you… 1 2046 |
