Forum Building A New House 1 May 26, 2010 12:21 pm Just have a question re laying Vinyl timber planks, do you have to do anything to the concrete slab before laying, I believe you just glue Vinyl directly onto concrete slab? if this correct Any assistance appreciated. Site Start: 10th September, 2010 PCI : Friday 27th January, 2011. Handover: 3rd February, 2011 Build Thread: viewtopic.php?f=31&t=37677 Re: Calling our Flooring Guru's 2May 26, 2010 12:30 pm I guess it depends on if they are the hard or the soft ones - some are on a backing that makes them solid, some aren't and they are just a floppy vinyl strip. The hard ones should be mostly good to go down as is. The soft ones are a different story - as with laying any soft vinyl: You will need to make sure that the surface is nice and flat and smooth. Many floorlayers would likely give a floor a thin coating of ardit and a sand to flatten any bumps or holes. Imperfections tend to show through those planks. It's not a really expensive process (vinyl can be one of the cheapest materials that you can use on your floors, and some of it can look magic. The latest design of wood strips look amazingly real), it just helps to know how. Also, if they are straight vinyl (without the hard backing) strips and you are not arditing the floor before laying, make sure that any writing done on your slab by the tradies is sanded away or otherwise removed before laying. Over the years it can leach through and you may end up with circles, lines, numbers, etc on your otherwise lovely planks. Depending on the thickness of the vinyl it can happen in a matter of months. Hope this helps!! Re: Calling our Flooring Guru's 3May 26, 2010 12:35 pm Thank you somewoman, we are thinking of using the new Wood Look vinyl planks like Karndean etc, thought we would have to get something done to slab. They are pretty pricey already I had a quote of $120pm laid, but they didnt mention any work to the slab beforehand, guess I will have to check out how much this would be. Thanks again Site Start: 10th September, 2010 PCI : Friday 27th January, 2011. Handover: 3rd February, 2011 Build Thread: viewtopic.php?f=31&t=37677 Re: Calling our Flooring Guru's 4May 26, 2010 1:25 pm their laying fees should cover any prep work that they need to do. Worth asking them about it. 1 187 ![]() What sort of brand of rangehood are you getting? You need to check in the rangehood specs as to the type and size of the duct. All rangehoods are different. The duct you… 1 446 ![]() Im building double storey with them and carpet is included in all bedrooms, upstairs living areas and home theatre room. All other rooms are tiled. You have the option… 2 530 |
