Browse Forums Building A New House Re: Perth,Updated house plans,do we need to re-think anythin 561Nov 10, 2010 10:47 am A friend has one that fold out from the wall,its in a stupid spot & really does not work at all. I have to have a sqiz on the web,have seen things in the past but as it was a long way off thing i didn't take enough notice. So i know something is out there,just gotta find it as plans need to finished VERY soon. I'm sure i saw one that was fitted to to top off the inside of laundry cupboard & it just slid out & back again Maybe i may have to have just a thin cupboard for the board,maybe i can do something in the linen PRESS,have to make my cuppa & have a lookie. God,more maybe's Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Perth,Updated house plans,do we need to re-think anythin 562Nov 10, 2010 1:13 pm Hi Kerry, My mum put one of these in her laundry and a small plasma fixed to the wall in front of it - awesome setup and definitely changed my views on ironing as a chore! We've done the research on these for people before, they can definitely get quite expensive when integrating with your laundry cupboards. Also be wary of which one is used as there is some cheap nasty one's out there. The one in my parents place we ended up modifying and putting a double lock on as the one lock wasn't sufficient to keep the board steady. You also want to check the dimensions of the board as some of the standard ones have pretty small ironing boards as they were originally designed for hotels etc. with compact cupboards. Brick pict/colourbond colours ???? 563Nov 10, 2010 3:28 pm jayw Hi Kerry, My mum put one of these in her laundry and a small plasma fixed to the wall in front of it - awesome setup and definitely changed my views on ironing as a chore!We've done the research on these for people before, they can definitely get quite expensive when integrating with your laundry cupboards. Also be wary of which one is used as there is some cheap nasty one's out there. The one in my parents place we ended up modifying and putting a double lock on as the one lock wasn't sufficient to keep the board steady. You also want to check the dimensions of the board as some of the standard ones have pretty small ironing boards as they were originally designed for hotels etc. with compact cupboards. Thanks Jay, Yep us mums have some good ideas. Some on here are even having one in their ensuite Here is a pict of the bricks with colourbond roof colours Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Colours are - loft,jasper,bushland,dune,evening haze. Too light a colour may look too washed out Has to be earthy Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Perth,Updated house plans,do we need to re-think anythin 564Nov 10, 2010 5:38 pm K.A, when you put the photos up, is there any way you can make them bigger. I cant see very well Re: Perth,Updated house plans,do we need to re-think anythin 565Nov 10, 2010 5:53 pm Dunno Have to check that out or Put your glasses on Do the squint test Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Perth,Updated house plans,do we need to re-think anythin 566Nov 10, 2010 5:59 pm I have no idea how to make it bigger. But I do like the jasper and bushland. Re: Perth,Updated house plans,do we need to re-think anythin 567Nov 10, 2010 6:28 pm Now this maybe a doh moment, but are you clicking on the pict which will take you to pb which shows it bigger Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Perth,Updated house plans,do we need to re-think anythin 568Nov 10, 2010 7:32 pm ha ha I had a giggle....Thirsty it gets bigger when youclick on it (doesn't everything My vote is bushland and then our houses can be twins (except I doubt you will go with Manor Red gutters like us weirdos). What are your bricks called again? I really like them. We are having Austral Georgraphe Limestone Bricks, Bushland Roof, Woodland Grey Finials, Manor Red Gables, gutters and roller door..........as someone said to me, its going to look very similar to a Hungry Jacks! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Happy, Healthy Free Range Wessex Saddleback Pigs My doom and gloom paperwork nightmare viewtopic.php?f=31&t=32170 Construction viewtopic.php?f=31&t=43653 Re: Perth,Updated house plans,do we need to re-think anythin 569Nov 10, 2010 8:00 pm K-A I like the top three roof colours with your bricks. I'd be worried the bottom 2 would be too light. Re: Perth,Updated house plans,do we need to re-think anythin 570Nov 10, 2010 8:16 pm I did click on it but I dont want to click on it cos Im lazy V, Good colouring in skills. Can you do mine Re: Perth,Updated house plans,do we need to re-think anythin 571Nov 10, 2010 8:31 pm Velouria ha ha I had a giggle....Thirsty it gets bigger when youclick on it (doesn't everything My vote is bushland and then our houses can be twins (except I doubt you will go with Manor Red gutters like us weirdos). What are your bricks called again? I really like them. We are having Austral Georgraphe Limestone Bricks, Bushland Roof, Woodland Grey Finials, Manor Red Gables, gutters and roller door..........as someone said to me, its going to look very similar to a Hungry Jacks! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Its the first one Naughty V ,Ok smarty pants how did you do THAT Have to get the roof colour & then work on the rest,a friend (yes i have 1 ) said to have it all the same Kexkez,i agree too light Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Perth,Updated house plans,do we need to re-think anythin 572Nov 10, 2010 8:35 pm Thirsty - sure I'll give it a go (he he he he ) I will post my creation on your thread. I agree with Kexkez. The bottom two are too light. Have you thought about a green - Wilderness or PaleEucalypt? What colour are you thinking for fascias/gutters/roller door? Happy, Healthy Free Range Wessex Saddleback Pigs My doom and gloom paperwork nightmare viewtopic.php?f=31&t=32170 Construction viewtopic.php?f=31&t=43653 Re: Perth,Updated house plans,do we need to re-think anythin 573Nov 10, 2010 8:38 pm kerry-ann Naughty V ,Ok smarty pants how did you do THAT Have to get the roof colour & then work on the rest,a friend (yes i have 1 ) said to have it all the same Kexkez,i agree too light Well it wasn't that hard really. I can give yours a try if you have a picture of the elevation (JPG) and giveme details of your bricks etc. Its not perfect, but it gives a bit of an idea when choosing colours Happy, Healthy Free Range Wessex Saddleback Pigs My doom and gloom paperwork nightmare viewtopic.php?f=31&t=32170 Construction viewtopic.php?f=31&t=43653 Re: Perth,Updated house plans,do we need to re-think anythin 574Nov 10, 2010 9:26 pm OOW, I'm excited Will this do,bricks are 2 coarse,the gdoor will be the timber look & timber front doors DO YOUR MAGIC,V :lol: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ cheers & thanks Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Perth,Updated house plans,do we need to re-think anythin 575Nov 10, 2010 9:50 pm KA - what are your bricks and have you decided on your window frame colour? Happy, Healthy Free Range Wessex Saddleback Pigs My doom and gloom paperwork nightmare viewtopic.php?f=31&t=32170 Construction viewtopic.php?f=31&t=43653 Re: Perth,Updated house plans,do we need to re-think anythin 576Nov 11, 2010 10:08 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Its a bit of a bodge job as DS was at my elbow Its Bushland roof, Tivoli bricks and Woodland Grey gutter. Let me know what other combo you would like and I will have a go (when DS in bed) Happy, Healthy Free Range Wessex Saddleback Pigs My doom and gloom paperwork nightmare viewtopic.php?f=31&t=32170 Construction viewtopic.php?f=31&t=43653 Re: Perth,Updated house plans,do we need to re-think anythin 577Nov 11, 2010 10:52 am Gee thanks V I think we have found our very own COLOUR DESIGNER!!!!!!!!!!!!!!!!! Sorry i did not get back here last night,kiddies drama's Mmmmm,don't know,are you able to do the other colours as well PLEASE Needs to be warm,inviting & dare i say that word again EARTHY. This is hard,i cant even think of gutter etc colours,i do know PB has Jasper roof & dune gutters,could you try that one V. Those bricks don't look very good do they Block bought 1st RBC X! 2nd Ventrua,Keeper! Pstart 18/7/11 Ethwks jan 2012 Slab Bricks- finished 7/6 Roof Trusses 15/6-cbond 21/7 viewtopic.php?f=31&t=41185 Re: Perth,Updated house plans,do we need to re-think anythin 578Nov 11, 2010 11:04 am I had to distort them a bit so they look a bit naff, but I will fix them up. I really like them on the Brikmakers website, but I guess as with most things you really need to see them in person. I am only mucking around using Microsoft Paint so it is pretty basic - somewhere to start I suppose. Will try Jasper/dune combo next with same bricks Happy, Healthy Free Range Wessex Saddleback Pigs My doom and gloom paperwork nightmare viewtopic.php?f=31&t=32170 Construction viewtopic.php?f=31&t=43653 Re: Perth,Updated house plans,do we need to re-think anythin 579Nov 11, 2010 5:21 pm Wow, V - I like that one of K.A's Re: Perth,Updated house plans,do we need to re-think anythin 580Nov 11, 2010 5:46 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is Jasper Roof and Woodland grey gutters. I took the liberty of upgrading your front door too (I hope you don't mind) I just realised I used the wrong bricks...be back in a mo Happy, Healthy Free Range Wessex Saddleback Pigs My doom and gloom paperwork nightmare viewtopic.php?f=31&t=32170 Construction viewtopic.php?f=31&t=43653 I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 36934 Really tight at the top of the stairs- how to get furniture into those rooms? Study books - does anyone really use them these days? Large storage closet would be more functional. 2 6882 No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6623 |
