Browse Forums Building A New House 1 May 10, 2010 2:34 pm I'm ready to do my final inspection on my new home. We have had lots of access to the house during the build and our concerns have been addressed during the building and at this point we cant find any major problems. Do i need to get a building inspector to go through the place? Re: building inspections??? 2May 10, 2010 2:57 pm It really depends on what technical experience you have. Visual checks on finishes etc. are okay as long as you take your time and check everything from all angles. But do you know building regulations to be able to check that they have been adhered to, although at this late stage most of it is hidden behind plaster. If you take a ladder with you are you competent enough to climb into the roof space and check that insulation, wiring etc. is all okay? You need to base your decision on whether to have a professional do it for you on your own abilities and experience. Good luck, hope all is well and that you are in your new home shortly!! Re: building inspections??? 3May 11, 2010 9:54 pm Thanks klscomps, you are absolutely right, i am not capable of such a thorough check. Meeting has been booked for Wednesday and hopefully settlement with follow shortly after. We're so looking forward to getting back to our own home again and unpacking all that has been in storage for the last few months. You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18083 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110585 |
