Browse Forums Building A New House 1 May 03, 2010 4:39 pm Hi guys After running around for a while I have decided to build Foxley 26 with Porter Davis. I have made a bit of modification to it and have removed the wall between the Lounge room. Therefore, now I have a bigger Family area. http://porterdavis.com.au/content/House ... xley26.pdf I like the plan now but I am confused on how to get a good outdoor area coz I cannot extend the patio since my block is only 16 m wide. I do have 7.5 meters in the backyard. Any suggessions about the alfresco ?? and any feedback about the floor plan Thanks Manu Re: Building Foxley 26 - Porter Davis 2May 03, 2010 4:59 pm Hi Manu, Welcome, and I like your floorplan. Not an inch of wasted space from what I can see. As far as an outdoor area probably Somewoman on this forum is the guru of these types of questions. I'm sure she'll show up sometime today and may have some suggestions. Handover February 2011 Happy with our home Re: Building Foxley 26 - Porter Davis 3May 03, 2010 6:19 pm Manu82 Hi guys After running around for a while I have decided to build Foxley 26 with Porter Davis. I have made a bit of modification to it and have removed the wall between the Lounge room. Therefore, now I have a bigger Family area. http://porterdavis.com.au/content/House ... xley26.pdf I like the plan now but I am confused on how to get a good outdoor area coz I cannot extend the patio since my block is only 16 m wide. I do have 7.5 meters in the backyard. Any suggessions about the alfresco ?? and any feedback about the floor plan Thanks Manu Hi Manu... Welcome to H1... I like your plan heaps - I think it uses space well. Thinking about the Alfresco that you want... did you need the 4 bedrooms + study? If you did then my idea wouldn't work, but if you were happy with 3 beds + study: considering the fact that you have opened up the living room area by removing the lounge wall - why don't you slot the Rumpus in the place of Bed 4 and then use the old Rumpus area as your Alfresco? It will all still be under roof line then and can include your existing patio area and you will be able to take advantage of the large backyard?! Just some food for thought!! Regards Sleven! Sleven Moved into our Atlantique MkII 36 by Carlisle Homes Re: Building Foxley 26 - Porter Davis 4May 04, 2010 4:53 pm Thanks guys... One suggession that a friend has given me is to get a sliding door in the rumpus room. That ways I could get a pagola just outside the rumpus room... What do u think about that ?? That is how they have done it in the display house too... Re: Building Foxley 26 - Porter Davis 5May 05, 2010 10:14 am We built the Foxley 26 and modified it by removing the same wall you are and sliding in the bifolds door to remove the 'dining', and allocated the lounge area as dining by tiling it. We also added .6m onto the back of the house to make bed 3 & 4 and the rumpus larger. There are floorplans in our thread (link below). Good luck! Re: Building Foxley 26 - Porter Davis 6May 05, 2010 3:39 pm hey gumboots... I just checked your thread and I must say you'v done a really good job with the colors and the floor plan.. I like it a lot !! I am assuming PD would have charged you for adding 0.6m on the back...seems like a nice idea. can I ask approximately how much did that cost ?? And do have a sliding door in the rumpus ? Thanks Manu Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 12345 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110592 |
