Browse Forums Building A New House Re: Custom Design floor plan thread post them here!! 21Apr 30, 2010 1:07 pm All good-I had to download it via Photobucket tho'and give my computer permission.... Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Custom Design floor plan thread post them here!! 22Apr 30, 2010 2:09 pm danrts...WOW! loving the views and the rain forest and the lushness.. WOW!! Neil..yours is pretty nice too!! We have a view out to whangarei heads...which means nothing to any of you, but it looks like yorkshire countryside. But I am LOVING all your views...SOOO tropical looking. Somewoman you should put up your awesome plan (the million dollar one) cos that was pretty special.. Nic Re: Custom Design floor plan thread post them here!! 23Apr 30, 2010 2:35 pm Mrs P Whoops I forgot about walls with my plan! That might add a bit extra ha ha, I thought walls were about 5 mm, bit of brick, some frame, gib,....how thick would all that be.. more like 220 mm I had to add.. hence the extra 25 sq mets that it added to my plan. good luck mrs p, do you have a sketch to show us all? (you know, the one that has really cool couches like danrts has..and mine had ) Re: Custom Design floor plan thread post them here!! 24Apr 30, 2010 2:54 pm Kiwi it gets a bit tricky trying to calculate walls when just drawing the sketch. Its more the internal walls that add the larger area because across the house if your just calculating the room size that you want you forget about the walls. Usually the internal wall sizes are either 70mm or 90mm, across the house there may be a total of say 8 walls length ways = 720mm plus the 2 external walls totals 1.2meters by the width of 8meters thats 9.6m2 and thats only one section while it might not seem much it all adds up to quite a bit especially if trying to keep to a budget. Does all that make sense? Budde Design 3D Architecural Visualizations, Architectural Rendering, Artist Impressions, 2D & 3D floor plans http://www.buddedesign.com nathan@buddedesign.com Re: Custom Design floor plan thread post them here!! 25Apr 30, 2010 3:06 pm As per your request =) This is the house that I designed (with some input from the hubby), then we sent it off to a green architecture firm for ideas and drafts. They didn't change the floorplan at all from what we had sent to them (which was awesome - they said that we'd REALLY gotten the green stuff right!!), and they came up with the awesome elevations. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And the one we are currently building: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Since we couldn't justify the cost of the above build (1.2million!!) we opted to go with a volume builder and modify the heck out of one of their designs to fit in all of the important aspects from our own design. It's almost the same house. The study in the one we are building is the playroom in the one above. The lounge in the one we are building is my office (the study in the one above) - which works better as I now have views to the playroom from my office. Hubby's office has been moved down stairs. Some of the spaces have been slightly reduced, but overall it's pretty much *** for tat. Below is the original Longridge Madison 255 (turned on its side to show the same orientation as my plan above) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Custom Design floor plan thread post them here!! 26Apr 30, 2010 4:42 pm Nathan, I saw what you were able to do for Mohammed with the colours - fantastic - I understand if you don't want to do this but I am having trouble deciding on our colours. I am attaching our elevation. The definite colours we have chosen are Austral Georgian red bricks (dark red with splashes of black) and a medium-darkish grey shingle roof tile. Am not sure about having gutters/window surrounds/garage door etc a combination of grey and white or just greys. Our windows have changed too they are now awnings (but I dont have an amended elevation sorry). Would love if you have something similar you could show me. It is hard to visualise as we are not rendering and most new builds are rendered these days. Thanks very much http://i858.photobucket.com/albums/ab144/lee75_2009/DSC01770.jpg Re: Custom Design floor plan thread post them here!! 27Apr 30, 2010 5:30 pm No worries Lee75 ill check it out for you. Budde Design 3D Architecural Visualizations, Architectural Rendering, Artist Impressions, 2D & 3D floor plans http://www.buddedesign.com nathan@buddedesign.com Re: Custom Design floor plan thread post them here!! 28Apr 30, 2010 6:23 pm Somewomen wow how good is that design haha im moving in.... Love the Elevations of your original are you having something similar im going to check your thread out. Budde Design 3D Architecural Visualizations, Architectural Rendering, Artist Impressions, 2D & 3D floor plans http://www.buddedesign.com nathan@buddedesign.com Re: Custom Design floor plan thread post them here!! 29Apr 30, 2010 7:03 pm nathanbudde Kiwi it gets a bit tricky trying to calculate walls when just drawing the sketch. Its more the internal walls that add the larger area because across the house if your just calculating the room size that you want you forget about the walls. Usually the internal wall sizes are either 70mm or 90mm, across the house there may be a total of say 8 walls length ways = 720mm plus the 2 external walls totals 1.2meters by the width of 8meters thats 9.6m2 and thats only one section while it might not seem much it all adds up to quite a bit especially if trying to keep to a budget. Does all that make sense? you lost me after tricky.... no, i get it now!. I was measuring from a line when I should have measured from 2 lines really.. totally understand it now...thank you for your explanation and also showing me on the paper what happens to a single line on a piece of paper (it gets thicker!) ...cheers somewoman, LOVE IT! Re: Custom Design floor plan thread post them here!! 30Apr 30, 2010 8:15 pm nathanbudde Somewomen wow how good is that design haha im moving in.... Love the Elevations of your original are you having something similar im going to check your thread out. nothing so cool. Longridge won't stray from the facades that they know! Maybenext time not too shabby for a computer programmer, hey? =) Re: Custom Design floor plan thread post them here!! 31Apr 30, 2010 8:24 pm Hey somewoman, I've often wondered .... why is a custom build so much more expensive? What's your take on it? Building on an acre in Macedon ......one day. Re: Custom Design floor plan thread post them here!! 32Apr 30, 2010 10:04 pm somewoman nathanbudde Somewomen wow how good is that design haha im moving in.... Love the Elevations of your original are you having something similar im going to check your thread out. nothing so cool. Longridge won't stray from the facades that they know! Maybenext time not too shabby for a computer programmer, hey? =) Your current design your building is pretty cool though. Yes you have done extreamly well i love your original! Budde Design 3D Architecural Visualizations, Architectural Rendering, Artist Impressions, 2D & 3D floor plans http://www.buddedesign.com nathan@buddedesign.com Re: Custom Design floor plan thread post them here!! 33Apr 30, 2010 10:36 pm danrts Here's my site plan, block photos and current concept. (LOT 24) I'm trying to alter the plan to have the living areas at the front of the block overlooking a pool and views down into the distance (rather than currently focussed towards the rainforest at the rear http://i69.photobucket.com/albums/i80/danielt25/siteplan.jpg http://i69.photobucket.com/albums/i80/danielt25/IMG_7435a.jpg http://i69.photobucket.com/albums/i80/danielt25/IMG_7439a.jpg http://i69.photobucket.com/albums/i80/danielt25/IMG_7444a.jpg http://i69.photobucket.com/albums/i80/danielt25/IMG_7422a.jpg I have roughly sited danrts plan on his block photo so you can see what he wants to achieve. As you can see the main bed and ens block the views from the living and pool area down to the valley, he is looking to maybe move the bedroom down towards the back and shift the living areas towards the front and the pool to the front so everything overlooks the valley. Thats right isnt it danrts? So any ideas for him would be great.... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Budde Design 3D Architecural Visualizations, Architectural Rendering, Artist Impressions, 2D & 3D floor plans http://www.buddedesign.com nathan@buddedesign.com Re: Custom Design floor plan thread post them here!! 34Apr 30, 2010 11:05 pm mummagoose Hey somewoman, I've often wondered .... why is a custom build so much more expensive? What's your take on it? From what I've heard, project home builders charge a whole lot less because they can basically buy all their supplies wholesale. They have their designs and they have "perfected" (I use this term very loosely) HOW to create those designs with minimal scraps and leftovers, so then know exactly what to order. Apparently. Some of them even order the frames already constructed to a given wall size - then they just put it all together like lego. They charge like a wounded bull for anything non-standard because it takes more effort for them to get it right, and because they can (they like to discourage people from too much non-standard stuff going on!!). Even the volume and project home builders that we spoke to who would do a custom designed home were still wanting to charge us approx 800k for that house - even with their volume discounts. We halved that by using Longridge's design and modifying it to what we wanted. We upped their standard pricing massively in doing so, but it was still a whole lot cheaper to do it this way than to have a completely bespoke house. One of the reasons why we chose our builder was because they had the theory that if we were willing to pay for it. I guess it's like anything. You can buy a dress off a rack for under $100, but you have a tailor create the same thing for you - same materials, etc, but fitted perfectly for you - you pay $300 or more. You expect to pay more for the personalisation. Works the same with housing. In the case of the above house we also wanted to use things like thermally broken aluminium windows, polished concrete throughout, rammed earth walls. Even removing some of these and opting for cheaper materials didn't drop the price significantly enough to warrant spending the money on that house when we could get almost the same thing for a third of the price (give or take). We also wanted massive underground water tanks. The rammed earth did add $200,000 to the total cost above brick, but that alone just wasn't enough. I think it's also a matter of if you're putting SO MUCH into such a beautiful house, you really can't afford to skimp on the inclusions. That, of course, didn't help with the costs! At the end of the day, the design that we have is a beautiful house. It should actually perform better so far as solar passivity goes, and also allowed us to use above ground water tanks (which would have been in the way of windows in the other build, so below ground were the only aesthetically viable option) - so that alone has saved a LOT of money AND allows us to use the tanks to protect part of the house from the hot western sun, thus saving even more money on energy use. And we still haven't had to skimp on anything - it's all what we want, right down to building using fully rendered hebel power panel for its thermal benefits. Rammed earth would have been nice, but this works just as well. Feel like I'm waffling and still not getting out exactly what I want to say on the matter - there's a LOT to talk about on this one!! And my brain is not working today - bit over tired thanks to a teething baby So I might leave it at that and hope that it makes some sense and answers your question! nathanbudde Your current design your building is pretty cool though. Yes you have done extreamly well i love your original! We like the current design =) Would have been MUCH happier if they'd let us play around with the facade. At least I got my gorgeous front door that I wanted. As mentioned in the above novel, the design that we are building should actually function better as a solar passive home than the previous house. Since we no longer have the upstairs area to use as a thermal chimney we have added several openable velux roof windows (electric operation, which we plan to hook up to the CBUS to control opening and closing according to data from the weather station which will also be hooked up to feed information to the CBUS). Which is another thing - going for the cheaper design allowed us to spend a lot more on things like CBUS - so instead of a basic CBUS system to drive lighting the house, we have been able to hook up home automation to pretty much anything that can be automated. So we can have the house effectively drive itself and issue alerts via email/sms/other means when it requires an action from us - ie, open or close the retractable blinds if too much sun is heating up the house, turn on the aircon and automatically open the roof windows if the inside temp is hotter than outside, tell us to open the main windows if the outside temp is cooler than inside, etc. We will also automate transfer of heat from the living area to the sleeping areas in winter (as most of the heat from the sun will be in the main living zone - a lot of heat will be captured in the thermal chimney/roof window shaft and can be transferred from there to other areas via simple duct/fan system which will be powered on/off and speed of fan by the CBUS according to temperature data). Lots more fun stuff, too! All stuff that we couldn't have afforded with the original design. So, apart from my beautiful facade, I really don't feel like I've missed out on much. Oh, the wall of window in the shower looking out into the private garden would have been nice - I'll miss that Re: Custom Design floor plan thread post them here!! 35Apr 30, 2010 11:22 pm danrts Here's my site plan, block photos and current concept. (LOT 24) I'm trying to alter the plan to have the living areas at the front of the block overlooking a pool and views down into the distance (rather than currently focussed towards the rainforest at the rear Hi danrts Are you looking for separation of master and other bedrooms? Seems to me that it would be pretty easy to basically swap the locations of living and master bedroom wings - they're approximately the same size (give or take), and would fit nicely in each others spot. You could have glazing front and rear of the living areas, so views to the valley at the front and views to the rainforest (and did you mention swimming pool?) at the rear. You could have the master bedroom looking onto a garden (being that space currently between bed2, lounge and rumpus) with the study and bed 2 at the back sharing the hallway with the other bedrooms. Will throw something together and post it for you. You're welcome to hate it if you choose!! =) Re: Custom Design floor plan thread post them here!! 36Apr 30, 2010 11:51 pm danrts okies - here's what I'm thinking... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ nice garden between master and lounge, and master should even have views of the valley if all curtains are open between!! Might have to rearrange things slightly if you'd prefer master bedroom to have rainforest views. Either direction, your views are stunning! I've slightly rearranged the ensuite. Gives you a bigger shower (two shower heads??) and vanity area this way, but takes up less space. I've swapped the location of laundry and powder room so that guests have easier access to the powder room without having to go tromping off into your bedroom area, but this isn't a necessity. your house, your way =) The bed5/study is now an odd shape, and a bit bigger than it used to be. This is to allow for passage way. Otherwise there was a huge landing-style area just sitting there doing nothing (which you may like - use as a library or a quiet sitting area with a little coffee table and a comfy chair?). Re: Custom Design floor plan thread post them here!! 37May 01, 2010 12:47 am Hey Nathan How big do you think this place would be? I'm working on a design for the next house and don't want it to be too big. I think 25sq is as big as we would want to go (that's 25sq of living + garage + alfresco). I don't have any real size requirements for the room at the moment, all I know is that the garage will be at least 7m wide, so that might give you a bit of an idea on proportions for the rest of the place. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Would love it if you get the chance to do this one up for me Re: Custom Design floor plan thread post them here!! 38May 01, 2010 1:58 am Dilla, that's a massive hallway going past all bedrooms to get to the living/entertaining areas. Do you have young kids who could be woken by visitors coming and going, or salesmen knocking on your door during their nap times? If you want the long hallway then it's all good, but personally I would think it a pretty big turn off for a huge percentage of potential buyers should you ever need or want to sell... Re: Custom Design floor plan thread post them here!! 39May 01, 2010 11:09 am dilla Hey Nathan How big do you think this place would be? I'm working on a design for the next house and don't want it to be too big. I think 25sq is as big as we would want to go (that's 25sq of living + garage + alfresco). I don't have any real size requirements for the room at the moment, all I know is that the garage will be at least 7m wide, so that might give you a bit of an idea on proportions for the rest of the place. Would love it if you get the chance to do this one up for me Dilla no problems ill check it out for you. I have sent you a PM aswell Budde Design 3D Architecural Visualizations, Architectural Rendering, Artist Impressions, 2D & 3D floor plans http://www.buddedesign.com nathan@buddedesign.com Re: Custom Design floor plan thread post them here!! 40May 01, 2010 11:16 am nathanbudde Your current design your building is pretty cool though. Yes you have done extreamly well i love your original! We like the current design =) Would have been MUCH happier if they'd let us play around with the facade. At least I got my gorgeous front door that I wanted. As mentioned in the above novel, the design that we are building should actually function better as a solar passive home than the previous house. Since we no longer have the upstairs area to use as a thermal chimney we have added several openable velux roof windows (electric operation, which we plan to hook up to the CBUS to control opening and closing according to data from the weather station which will also be hooked up to feed information to the CBUS). Which is another thing - going for the cheaper design allowed us to spend a lot more on things like CBUS - so instead of a basic CBUS system to drive lighting the house, we have been able to hook up home automation to pretty much anything that can be automated. So we can have the house effectively drive itself and issue alerts via email/sms/other means when it requires an action from us - ie, open or close the retractable blinds if too much sun is heating up the house, turn on the aircon and automatically open the roof windows if the inside temp is hotter than outside, tell us to open the main windows if the outside temp is cooler than inside, etc. We will also automate transfer of heat from the living area to the sleeping areas in winter (as most of the heat from the sun will be in the main living zone - a lot of heat will be captured in the thermal chimney/roof window shaft and can be transferred from there to other areas via simple duct/fan system which will be powered on/off and speed of fan by the CBUS according to temperature data). Lots more fun stuff, too! All stuff that we couldn't have afforded with the original design. So, apart from my beautiful facade, I really don't feel like I've missed out on much. Oh, the wall of window in the shower looking out into the private garden would have been nice - I'll miss that [/quote] How awsome is the CBUS. A luxury design builder i used to work for built a show home that won alot of awards etc and they had a $60k CBUS in the home. It was amazing, was an absolute pleasure to work out of and everyone was amazed by the CBUS. Budde Design 3D Architecural Visualizations, Architectural Rendering, Artist Impressions, 2D & 3D floor plans http://www.buddedesign.com nathan@buddedesign.com Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25171 6 55355 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20432 |
