Browse Forums Building A New House 1 Apr 29, 2010 5:34 am Hi, We are currently in the design phase of building a relatively small house in the back of a existing property. Our maxium allowable dimensions for the home is 13.2 wide and 14 deep. The counsil will allow us to build a 1 1/2 story design also. What we are finding to be difficult is a suitable house plan for this relatively small dimension. Has anyone had experience or can provide some advice in this situation? Regards Re: Small home designs 2Apr 29, 2010 8:22 am How many bedrooms do you need for the house? Where are you building? There is a builder called Post and Beam builders who have house plans that are modular. They are based in Victoria but do houses in sourthern NSW. Their basic module is even smaller than that and then they build it up. The webiste shows the different modules. If you search for them you should be able to find them. The kit home builders also seem to do smaller houses. But I only really done los of looking at NSW builder designs Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: Small home designs 4Apr 29, 2010 11:48 am I have only really looked at builders from NSW as I live there. I got a magazine called buildhome from the newsagent which has lots and lots of builders in it. Then just went to their websites and trawled through the plans. If I was lucky, they would also have a display home nearby and I would go look at it as well. There is also a place in Narellan called Stonekit homes, which do sandstone homes and they have some compact 3 bedroom designs. Cheers Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: Small home designs 5Apr 29, 2010 2:19 pm Other than 3 bedrooms to you have any other requirements? Budde Design 3D Architecural Visualizations, Architectural Rendering, Artist Impressions, 2D & 3D floor plans http://www.buddedesign.com nathan@buddedesign.com Re: Small home designs 7Apr 30, 2010 8:03 am no dramas and also after a Garage in that dimension also? I will see what i have. Budde Design 3D Architecural Visualizations, Architectural Rendering, Artist Impressions, 2D & 3D floor plans http://www.buddedesign.com nathan@buddedesign.com Re: Small home designs 9Apr 30, 2010 2:29 pm By 1 1/2 storey, does that mean that they will let you go split level, or the maximum height would be 1.5 storeys - ie, you can build down also to make it double storey? Do you have any contour details of your block? Re: Small home designs 10Apr 30, 2010 3:23 pm I'd say it means you can angle the roof pitch to allow other rooms upstairs and use gabled windows. Alot of European and American houses have this. You end up with pitched ceilings in the upstairs rooms but it keeps down the maximum height of the building and its cheaper. I'd try some small custom builders and come up with you own plan for this sort of design. You could for example have the master bedroom, study and ensuite upstairs with gabled windows and all other rooms downstairs. Would anyone on this forum know of a builder/company in Brisbane with house designs for a shallow block. I have a block 20 x 20 so with front and rear set backs I need a… 0 4743 Your best bet might be to go visit the display homes and walk around in them, and take photos. Get a feel for it in person instead of deciding from the floor plan. There… 1 21437 Hi all, We are looking to build a new two storey house in western Sydney. Can anyone recommend a smallish builder to go with? We are trying to stay away from the big… 0 12140 |
