Browse Forums Building A New House Revised plan for comment with better laundry access 21May 08, 2010 12:33 am Thanks for all of the comments and suggestions. I talked to my wife about the issue of going through the pantry to the laundry and she agreed with everyone. So some redesigns were then planned. Modifications made in this plan: 1. House widened by 35cm. 2. Main bedroom / ensuite / WIR redesigned to accommodate extended hallway to laundry 3. Linen cupboards moved to main spine wall to make stepped wall with brick fireplace in centre (was thinking of using that stone wall product instead of brick but can't decide)to better utilise this space 4. Pantry slightly modified 5. Main bathroom heavily modified So here it is. There appears to be a small wall in front of the island, disregard this. Just put it there to help with measurement of kitchen and lounge areas and forgot to remove it. I have also put in all the room dimensions as well as overall house dimensions. I have also reduce the eave width down from 900mm to 450mm. I figure with all that veranda and patio area which is under main roof (roof is one big rectangle) they would act like giant eaves anyway. Will have some deciduous fruit trees to help with shading along eastern side where the bedrooms are. There is a beautiful established scribbly gum that will help block out some of the western sun into the kitchen and rumpus. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The window placements are not set in stone and the plan does not show window / door sizes. For the bathroom and ensuite, I was reading other threads which suggestered high thin windows and I liked the look so that's what they are. Between the rumpus and kitchen is also a wall cut out that will have timber shutters. The rectangle bit that cuts into the office and garage is a recess in the wall for the TV and AV equipment to sit in (negates the need for an entertainment unit and keeps them away from toddlers little fingers). As before, comments, advice, critiques always welcome. Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: My final house plans (version 287...) 22May 09, 2010 11:19 am Well I'm happier! Have you thought about just having a fixed glass screen in the ensuite to make it a shower "room" effect? Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: My final house plans (version 287...) 23May 09, 2010 4:42 pm What I want to do with both showers is to have them as doorless showers. The main bathroom will have a glass wall and was not sure if to have a glass wall in the ensuite or a solid wall that only goes up 2 metres. I love the idea of door less showers and hinges or tracks for gunk and mould to build up in so less cleaning. However I am worried about using a glass / perspex shower wall. We have one in our current house (on a sliding door to shower and it is no longer clear due to the water hitting it thingey (there was a proper name for the damage constant water hitting it is). Does this happen with glass or only the perspex? Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Plans ready for draftsman and house just got a buyer 24Sep 05, 2010 10:18 pm Well, After some more playing around, reflection, research, discusses with DW, We have come to the final plans. Which is lucky as someone agreed to buy our house today (pending contract exchange). Best of all, they are buying it as an investment property so we don't have to move out and will rent it off them. So no moving but can now afford to start building. Here are the plans that are ready to go to draftsman. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ There have been quite a few changes made. For one, the roof now has a valley! We changed it to a sort of L shaped as the giant patio would have meant not enough northern sun into living areas as roof would have blocked it. All of the gree walls are going to be 90mm masonry walls to act as thermal mass within the building envelope. The fireplace will be a through wall jobbie so in lounge room looks like a fireplace with a mantle piece (in stacked stone if we can afford it) and hallway side will look like a pot belly stove but recessed in so a fire grate can be installed to protect little kid fiingers. The main bedroom, ens, and WIR has undergone big big big changes but still has walk in shower, as does main bathroom which is what I wanted. No longer have a mud room but have tried to shrink down size of house and fixtures to save costs. So while there is still a very long way to go, we have at least achieved one more teeny tiny step along the way. (I also completed BASIX for the house - all the draftsman quoted me $450.00 to get a BASIX certificate. If you know what you are building, then you can complete it in an hour online for FREE, so already saved me some cash). Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: My final house plans (version 287...) 25Sep 06, 2010 8:28 am Now we just have to work out if we can afford to build the house. Only so many corners you can cut... Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: My final house plans (version 287...) 26Sep 06, 2010 1:01 pm Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: My final house plans (version 287...) 27Sep 06, 2010 1:48 pm Excellent idea to have equal-sized bedrooms for the kids, no fighting in your house Your ensuite/WIR design utilizes the space really well too! The only thing that i would change - i'd add a door into the hallway to access the entry. Although i actually like long corridors, i'd hate to be studying in Bed4 and to walk a mile to answer the front door.. not a major issue, just a suggestion? Goodluck your build! Re: My final house plans (version 287...) 29Sep 06, 2010 2:31 pm Quote: The only thing that i would change - i'd add a door into the hallway to access the entry. Although i actually like long corridors, i'd hate to be studying in Bed4 and to walk a mile to answer the front door.. not a major issue, just a suggestion? Goodluck your build! Just what I was about to suggest ;o) Quote: What about an opening just after the entrance so people don't have to walk through the living area to get to the bedrooms? I'm not sure what I would pick! I guess maybe just and opening??? Do you have little kids or big ones? The only reason I ask is my inner 16yr old is thinking "very easy escape route" with out a lockable door ;o) Amazing_Venice [size=50]Signed: 31/07/10 Colour Appointment: 08/09/10 Deposit Tender 20 / 09 / 2010 Final Contract Signed 18 / 11 / 2010 Slab laid 02 / 2 / 2011 Frame completed 25 / 02 / 2011 viewtopic.php?f=31&t=37417&p=553032&hilit=oxford#p553032 Finding ways to make it cheaper to build 30Sep 06, 2010 10:41 pm I only have 1 little kid thus far but may inherit a teenager and plan to have another one. I like the idea that it will be harder for them to sneak out as have to come up the hallway. It also allows me to zone the house more. In the future, I am considering closing off the foyer with a door so not wasting energy heating or cooling a space that in reality will most likely be there for show (given the driveway goes around whole house and parking is at the back, most people will be knocking on the sliding door to the lounge room. Although we are still not sure about build cost. The plan is to build the shell and structure as quality, with quality appliances, insulation etc. Then other fixtures, such as wardrobe shelving, skirting boards, laundry cabinets, light fittings, etc will be cheapies and then when we can afford it, upgrade them to higher spec level. Also verandahs will just be part of the slab and when we can afford it, put decking on top of it. But will see what the costings say... Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Plans back from draftsman, now getting quotes 31Mar 01, 2011 10:27 pm Hi all, After much derring do, I found a draftsman that I liked, sustained a roofing injury, and had the plans properly drawn up. There are more changes to the plans but mainly doors moving and verandah posts moving for structural reasons. The front bedroom is no longer the same shape as the other two but is still the same size (needed to alter it to centre the front windows and doors to the verandah posts). I also have a mudroom back again in the laundry which is great. Here are the piccies! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I am now currently getting building quotes. So far we have received one quote back which was for 284k with everything but painting inside and out. I was really happy with this qoute as plan to owner build and save money and if the quote from a builder was only this much, then my costs to build should be within my budget range. I am just waiting on three other quotes, two from other builders and one from a guy who will project manage the build for me but is getting raw quotes for me. I will pay him by the half day to oversee the tradies and make sure they are doing a good job and I know him and he is not from a place called dodge. I am also submitting my plans for approval with the community association as need to do this before lodging a DA. luckily this is no cost so if the costings come back too high and we have to go with a project home then I won't have wasted any money. Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: My final house plans (version 287...) 32Mar 01, 2011 11:56 pm looks good...only change I'd make is swapping bathroom and bed 2 around....just so bathroom can't be seen while sitting at breakfast bar...i know, there is bound to be a door on the bathroom, i feel it just makes the bathroom a little more central but I guess that would help keeping all the plumbing works in the one place how you have it now. Good luck Re: My final house plans (version 287...) 33Mar 02, 2011 12:32 am Hi Barker, I love the plans. I have been enjoying following this thread as I am in the same boat but a few months behind you. Does the quote from the builder include the verandah and alfresco? We are getting quotes at the moment and I am not getting near that price due to my verandahs and alfresco. Re: My final house plans (version 287...) 34Mar 02, 2011 5:37 am Hi Chook, you guessed right about wanting all the plumbing as close together as possible. The bathroom door will be kept closed though as it will be the kids bathroom. Countrylife, yes the quote includes the verandahs and alfresco because all of that is under the main roof. Did this to simplify construction and save costs. Does not look as nice as the separate verandahs or bullnose verandahs but a lot cheaper. Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: My final house plans (version 287...) 35Mar 02, 2011 6:51 am barker Hi Chook, you guessed right about wanting all the plumbing as close together as possible. The bathroom door will be kept closed though as it will be the kids bathroom. You could just reverse the bathroom & toilet and have the doors on the right hand side. Still keeps the plumbing together. Re: My final house plans (version 287...) 36Mar 02, 2011 7:18 am barker Hi Chook, you guessed right about wanting all the plumbing as close together as possible. The bathroom door will be kept closed though as it will be the kids bathroom. You could just reverse the bathroom & toilet and have the doors on the right hand side. Would still keep your plumbing together but solve the problem of looking straight into the bathroom. plans back from draftsman and now getting quotes 37Mar 02, 2011 7:30 am That is a possibility but my wife and I decided to go this way so it is easy to get to and find toilet from lounge room if people are over. Also (and this is a bit pedantic of me), it leaves things symmetrical the way that it is. Plus trying to watch the budget so any further changes would cost more to have plans changed. I am hoping to get second quote back today (when they said it would be back by). Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: My final house plans (version 287...) 38Mar 02, 2011 8:49 am Looks great! Interesting to see how your plans changed from the start of the thread. Good luck with it! For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Two more quotes in... 39Mar 03, 2011 9:26 pm They are 308k and 302k. So now I am thinking the 1st quote I got for 284k did not include GST. have emailed them to confirm. Otherwise it is interesting that there is such a price difference. But still waiting on my all important 4th quote... Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 And then reality hits home 40May 14, 2011 9:22 pm Well, after getting three quotes from builders ranging between 280-305k, I was really hoping the quotes for me to do it owner builder would still make my plan possible. I had a budget of maximum 250k and I have now reached 245k, not including paying the building manager, plumbing for the guttering, trenching and site connections, fixtures, plus about 10-20 other things. So it is easily going to go over 250k. Even if we decided to push it, it would mean not have any emergency money. As a result, my plans for building are going to be put on hold for a number of months. We are currently looking at an Allworth home but will take some time before committing to the next step. Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Really tight at the top of the stairs- how to get furniture into those rooms? Study books - does anyone really use them these days? Large storage closet would be more functional. 2 6884 i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98680 Hi, I am approaching end of the build. My final invoice will be given to me soon to pay. Some context before I ask my question. 1. My builder wont do the landscaping or… 0 3865 |
