Browse Forums Building A New House 1 Apr 25, 2010 5:37 pm Just wondering what cost you incurred when you upgraded from a colourbond to a wood look garage door? Also have you regretted doing so? I have heard that they fade quite a bot so I am a little worried in upgrading to then having to replace it in a few year but the colours I have chosen for my house look really well with this door RHI - BALDIVIS PERTH 2005 Bought/Finished WA Housing Centre Home 2010 Building the Benchmark with REDINK Homes in The Avalon 2013 Building the Michigan with Cont3nt Living In Highbury Estate! Re: Cost to upgrade colourbond garage door to wood look door 2Apr 25, 2010 8:31 pm Cost us $1,700 to upgrade from a colorbond rollerdoor, to a wood look steel sectional door. http://www.steel-line.com.au/site/produ ... _decro.cfm The actual wood ones will fade I believe, yes, and they're about +$3500. The steel was fine for us, looks good and stays that way. Re: Cost to upgrade colourbond garage door to wood look door 3Apr 26, 2010 12:25 am Our builder charges $295 for the Caoba upgrade. It really depends on your builder as I've noticed that each builder charges VERY differently. We didn't decide to go with it (after really wanting it for a long time) because too many houses in our suburb and the next one over had it installed so we just went for normal colorbond. Each to their own. Summit/New Gen Homes Slab - 9/4/10 PCI - 13/9/10 Handover - 22/9/10 Re: Cost to upgrade colourbond garage door to wood look door 4Apr 26, 2010 12:37 am Yep , Viva la Colourbond. If you are staying in said dwelling for a while wood will require maintance and in some ways, while we a want the front of the home to look good, It is the house that counts, not so much the garage. Timeline Aug 08-Land Mar 09-Demo/Titles Sept 10-Handover No1 Sept 11-Handover No2 April 12-Sold No2 Aug 14-Land/Demo Jan 15-Slabs viewtopic.php?f=31&t=25736 Re: Cost to upgrade colourbond garage door to wood look door 5Apr 26, 2010 3:36 am i was charged about $500 for the upgrade. Land - Northerly Estate, Piara Waters Titles Issues 05 April 2010 Building with Ross North Homes Prestart Completed 12 April 2010 Finance Approved 01 May 2010 Slab down 29 May 2010 Frame Completed 28 June 2010 Roof Completed 22 July 2010 Lockup 12 August 2010 PCI 24 Sep 2010 Handover 08 Oct 2010 Building Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=32295&start=0 Re: Cost to upgrade colourbond garage door to wood look door 6Apr 26, 2010 1:58 pm ibfragalot99 Cost us $1,700 to upgrade from a colorbond rollerdoor, to a wood look steel sectional door. http://www.steel-line.com.au/site/produ ... _decro.cfm The actual wood ones will fade I believe, yes, and they're about +$3500. The steel was fine for us, looks good and stays that way. The same Steel Line door was an $1800 upgrade for us. Re: Cost to upgrade colourbond garage door to wood look door 7Apr 26, 2010 2:27 pm Just a note - the upgrade cost will depending on what your upgrading from. If your upgrading from a basic rollerdoor, like myself and KnockItDown, it will be around $1700-$1800 extra as above. If your upgrading from a sectional door, then it appears to cost around $300-$500 extra. Re: Cost to upgrade colourbond garage door to wood look door 8Apr 27, 2010 12:46 am ibfragalot99 Just a note - the upgrade cost will depending on what your upgrading from. If your upgrading from a basic rollerdoor, like myself and KnockItDown, it will be around $1700-$1800 extra as above. If your upgrading from a sectional door, then it appears to cost around $300-$500 extra. Here in the west builders provide sectional garage doors as standard so the upgrade price is really for the wood-effect only. Rhi3384, a mate of mine got charged $900 for the upgrade which is one of the most expensive I have seen so far. You could always ring/email your builder to find out how much they charge. Summit/New Gen Homes Slab - 9/4/10 PCI - 13/9/10 Handover - 22/9/10 Yes i guess this is one of the main reason as i checked one post foundation 4 9982 Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 8486 Dover white or surfmist garage door. I am having trouble choosing a garage door. The outside of house will be tranquel retreat. I want it to all blend nicely however I… 0 6791 |
