Browse Forums Building A New House 1 Apr 25, 2010 9:06 am Which water pipe do people prefer - copper of PEX (cross-linked polyethylene)? I'm trying to decide between the two options. Apparently the cost is about the same. Ideally, the hot water system should: a) Provide hot water without much delay b) Not be affected by other uses turning water on or off (the hot shower when someone flushes the toilet trick) c) Not waste much water or energy. I guess these ideals are satisfied by the way the piping is configured. So what pipe material and what configuration is best? Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Which water pipe: Copper or PEX 3Apr 25, 2010 3:41 pm We went for copper - my dh is working with the pipe connectors used to connect the poly pipe - I think they are called Shark - and he is not happy as the o-rings are the first to go and they will end up leaking - we are going to for silver soldered copper piping (min 15%) for both water and gas. Preliminary agreement 23/11 Contract 22/03 Prestart 06/04 - finalised on 30/04 Unconditional approval 10/05 Demolition 05/07 Slab 26/08 Brickwork 13/09-06/10 Roof frame started 07/10 viewtopic.php?f=31&t=32292 Re: Which water pipe: Copper or PEX 4Apr 29, 2010 7:47 pm I hear that with PEX/plastic pipes it is possible to use a manifold system with no connectors between the manifold and the outlet. This wouldmena that there is no connector to fail. Demolition August 2009, Construction Started September 2009, Completed December 2010 DIY, Home Maintenance & Repair We have a hot water copper pipe that runs from our hot water unit on one side of our house under a concrete slab to our bathroom and laundry...old house so not ideal. The… 0 5107 OK it's been a little while! I've been busy getting time where I can to work on this. I started by grading a pad (borrowing a… 26 19966 yep sounds good make the footing bigger to to allow for the pipe in the middle 3 7298 |
