Browse Forums Building A New House 1 Apr 22, 2010 12:32 am i am gonna install some downlights in my dinning and living area after key hand over, so i just asked my builder to move the light point to one particular point, and i am gonna get someone else in and drill holes on the ceiling and do fitting in job later. is that make scene?? thanks home link viewtopic.php?f=31&t=34007 Re: light point & down light 2Apr 22, 2010 1:32 am i heard some story from my friend, they said thats really bad idea, they dont think this may be work. but the sale person didnt suggest me to set up all light points on the prestart meeting . what shoudl i do ? any solution from your guys???? home link viewtopic.php?f=31&t=34007 Re: light point & down light 4Apr 22, 2010 8:07 pm I don't see why it is a bad idea? It would certainly save you some money. We had all our downlights installed with the build because its something we really wanted done and the "after handover list" was already very long and expensive. I preferred adding the lighting cost to the mortgage and paying more for this reason. There are a number of ways it can be done. Place one batten light in one of the spots where you want a downlight so at least you have some lights when you move in. Then have an electrician come in and replace that with a downlight and install the rest for you. Make sure you are very specific that its for future downlights so the batten light is the required clearance from structural members. You can also have the builder install junction boxes in the roof at every downlight location and run them to your wall switches, setting up how you want them banked (ie. you may want to set up the lights so one switch only turns afew on to give you flexability with your lighting and save on operating costs when you dont need the room fully lit). Re: light point & down light 5Apr 26, 2010 1:10 am what size/measure of the conduit do i need to afford power for 6 downlight?? sorry, i am a beginner, i am just so confused, is the standard conduit provided by the builder good enough? or it must be upgrade to a better one which step is when the builder do light fitting and drill holes on the ceiling ? is that after ceiling job completed ? And how the electrician do the job , they get into the space between roof and ceiling or what??? home link viewtopic.php?f=31&t=34007 Re: light point & down light 6Apr 27, 2010 10:28 pm hello, when you say conduit... you want to say ' wire ' without going to deep into your problem, go with the standard builders light offerings. When the house is complete ring an electrician to install downlights for you. you will save up to $50.00 per light!! Any decent sparky will be able to create new switch lines/circuits, and place them where ever you want. Electrical - Automation - Smart wiring - New homes - Commercial - Data cabling] 1300 050 315 www.cenemelectrical.com.au www.facebook.com/cenemelectrical Building Standards; Getting It Right! Hi All, We have a fall from road to garage front. But we cannot put a drain/grate because no discharge point put by the builder. Now they complain not enough space for… 0 9252 Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6539 How long is a "long period"? For a few weeks, it should be ok. It also depends on the area you live in...I would let your neighbours know that you will be away too and… 1 28580 |
