Browse Forums Building A New House Re: Air Conditioning 7Sep 20, 2007 11:03 pm It seems quite common in Sydney. if you don't get their air con, you can't install it during the construction.
One other option is to get your builder to do the ducting pipes connection, then you decide on which machine to install after handover... Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 8996 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
