Browse Forums Building A New House 1 Apr 20, 2010 8:37 pm This could be a dumb question, so please bear with me. Our fridge cavity on the plans is 70cm deep. I am looking at purchasing a new fridge with a depth of 75cm, will this be an issue or do fridges usually stick out from the cavity a bit? We currently can't fit our fridge into the cavity at our rental (massive fridge, tiny cavity ) so I don't know what is "normal". Anyone want to have a quick look at their fridge vs. cavity and give an opinion? Thank you!!! Re: Fridge cavity vs fridge size? 2Apr 20, 2010 8:43 pm 60-70cm is usually normal. The doors will stick out infront of the cavity other wise you might have issues opening them fully. You might find the firdge is 75cm depth with Handles and door attached, but the actually fridge part might only be 60cm. Interesting... Built with Eden Brae Now building with Fairmont Homes NSW Re: Fridge cavity vs fridge size? 4Apr 20, 2010 9:37 pm I can't believe with all my planning prior to build, that I didn't think of this. Our fridge is huge and it sticks out about 20cm!!! It's a real pain in the ar... Smart person thinking of this first, I was so obsessed about the width & height, totally forgot depth! A thankful person is a happy person. [/color]My hobby design blog: http://aviewondesign.blogspot.com/ Re: Fridge cavity vs fridge size? 6Apr 20, 2010 10:04 pm 600mm is the standard with most project builders so you did well Re: Fridge cavity vs fridge size? 7Apr 21, 2010 7:20 am You can tell the build is going well just at this moment, as all I have to stress about is the fridge size Glad it wasn't such a dumb question after all! We are going with a small boutique builder so all of these things are negotiable (so I feel like I have to think of everything). Thank you! Re: Fridge cavity vs fridge size? 8Apr 21, 2010 10:38 am We made ours 1m deep, the fridge we want is 90cm deep. I can't stand seeing fridges sticking out of the space so wanted to make sure we had enough room (and agree about air circulation helping) Re: Fridge cavity vs fridge size? 9Apr 21, 2010 10:42 am Not a dumb question at all I forgot to check the depth of our fridge space and was a bit upset when it ended up sticking out...BUT if I had it flush with the cupboards I wouldn't be able to open the doors enough to access the veg crisper, so lucky I didn't think of it Hey guys, what’s everyone opinion on James Hardie linea direct fix to frame? Would this be the most common method and anybody ever had any problems down the track? 0 5150 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5638 I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 7530 |
