Browse Forums Building A New House Re: Install the ducted air-conditioning on double story home aft 2Sep 17, 2007 6:12 pm I have reverted to username - mattwalker Carlisle Homes - Grande 43 My building experience is here: http://www.ourgrandeplan.blogspot.com Re: Install the ducted air-conditioning on double story home aft 10Sep 21, 2007 8:40 am ahuang Got 2 questions, if you are getting your builder to do the ducting pipes, and then you get someone else to do the machine later, just wondering: 1. Don't you have to decide the zoning in advance? That would impact the way the pipes are connected. And I assume both have to match! Ducts from each room are run into the ceiling by the builder. All the zoning takes place in the ceiling via electric valves which are installed after handover. Quote: 2. There should be a control panel (or whatever you call that thing) for controlling the temperature of each zone. If the machine is installed after the handover, as the machine is normally installed outdoor and the control panel is normally upstair for 2 storey houses --- how are you going to connect the two? They run all the wires and pipes down the wall cavity after handover. It's no big deal. Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 8994 We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4087 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
