Browse Forums Building A New House 1 Apr 15, 2010 10:05 pm Installation of ducting complete - major success, but some sus results attached. Good Air Con or just con? Opinions? Pictures? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My signature is distracting people from my wise posts ... Re: Air Con - Have you checked yours? 2Apr 15, 2010 10:14 pm Lex, those two pics are not much to go on. Those cracks are superficial. They are only to help prevent condensation on a cooling system and to work as insulation to prevent heat getting into the duct work. They dont go right through. They will not leak. Re: Air Con - Have you checked yours? 4Apr 16, 2010 8:26 am It is just a basic plastic tube. I found a naked version of it. This one would be only suitable for heating systems. http://cgi.ebay.com.au/DUCT-Y-JOINER-PV ... ydroponics Re: Air Con - Have you checked yours? 5Apr 16, 2010 8:31 am I had no idea what I was looking at with those pics. Re: Air Con - Have you checked yours? 6Apr 16, 2010 9:08 am borg, interestingly enough, turns out that the A/C people are going to check and possibly replace some of that cracked tubing!! So it must be serving some other functions other than just housing the other (which appears to be) totally separate piece - !??!? Any A/C insiders to help out here?? My signature is distracting people from my wise posts ... Re: Air Con - where is IceMan when you need him!? 10Apr 17, 2010 8:00 am Wondering what would our resident a/c expert say about this issue ... IceMan?? Or, is there anyone else !?!?!?! Can we at least have an explanation on how are these connections designed - is our a/c going to leak ?!!? My signature is distracting people from my wise posts ... Re: Air Con - where is IceMan when you need him!? 12Apr 19, 2010 9:11 am Lex IceMan? AnyOne?? It's just spray on foam over the fittings... I wouldn't be worried about those small cracks... having said that if a client mentioned it I'd definitely change them because they're only about $20 a pop... Sorry I didn't pick this up earlier but I only ever look at the heating, cooling, etc forum...! Re: Air Con - where is IceMan when you need him!? 13Apr 19, 2010 9:29 am Ah, thank you, Iceman !!!! So, am I right to assume that the fittings inside this outer layer would be firm and fully sealed and we wouldn't have any leaks ??? And the fittings inside thsi foam - do you think that in our case (just by looking at my pics) it would most likely be the black plastic piping like borg mentioned? My signature is distracting people from my wise posts ... Re: Air Con - where is IceMan when you need him!? 14Apr 19, 2010 9:33 am Lex Ah, thank you, Iceman !!!! So, am I right to assume that the fittings inside this outer layer would be firm and fully sealed and we wouldn't have any leaks ??? And the fittings inside thsi foam - do you think that in our case (just by looking at my pics) it would most likely be the black plastic piping like borg mentioned? Yes to both... Re: Air Con - where is IceMan when you need him!? 15Apr 19, 2010 9:43 am Thanks again, IceMan!! Good to know that we can relax about those !!! (and I realise I should go and change the title of this thread !!) My signature is distracting people from my wise posts ... Re: Air Con - Have you checked yours? 16Apr 19, 2010 9:54 am Oh, and thank borg again too and apologise for seeking a second opinion (well, in my "defence", it was from the expert in this field !!!) - I was surprised when they said that they will send someone to inspect ... will update you all once I hear back from them! My signature is distracting people from my wise posts ... I've decided, after a period of confusion (my building broker told me it's probably not worth it to use a lawyer, but others have said it is a must) that I definitely will… 7 27957 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
