Browse Forums Building A New House Re: What to use for temporary driveway? 22May 02, 2010 9:28 pm cazoraz onc_artisan about $20 tonne delivered for a min load of 8 tonne.(a bit less than 4 cu mtrs) about enough for 40 sq mtrs / 100 mm thick is that for the crushed rock onc? from any sand & soil place? Like I said it is recycled concrete and no, not from any sand and soil place. you need to check with yellow pages or google it 'recycled concrete' Where you are coming from is where you are going to... Re: What to use for temporary driveway? 23Aug 06, 2011 12:57 pm I am in a similar situation. I have a driveway around 110 sqm and my builder is quoting $2500 for laying crushed rock for the trucks to pass. I want something that I can use later on for aggregate driveway that I want. I am sure that if look around I will be able to get this done much cheaper. so my questions are: 1) what size of crushed rock should I use so that I can use it later for aggregate driveway? 2) where can I get it? 3) I am in Bayswater VIC, any reccomendations? thanks, What to use for temporary driveway? 24Aug 06, 2011 4:11 pm Anyone got pictures of this recycled concrete down? We did ourdrive wY in tailings in the end but if this doesnt look too bad we could consider it for around the side of the house as an even cheaper alternative Hi JW I just read your post and I find this situation quite strange. When we build, we get a temp pole for construction which becomes the permanent pole for one of the… 1 3944 Hi all, Not sure if this is a good place for this question but I guess we'll find out! I'm a novice, building a modular room inside my garage/shed and need to create… 0 1856 That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor. 16 17857 |
