Browse Forums Building A New House 1 Sep 11, 2007 11:24 am I went through many display homes and found out most 1st floor have some hardiplank instead of brick, particularly at back of the building.
The hardiplank may be the cheaper solution,but how long it can last, and how easy to maintain?. I already see moisture, rotting of hardiplank in some new display home( less than 6 years old). It does not looking good as well. Does any concern having hardiplank on the new double-story home?. Thanks Eddy Re: what is pros and cons of hardiplank on the new double-story 2Sep 11, 2007 11:28 am You can ask to have it replaced with brick, for extra $$$ of course. Re: what is pros and cons of hardiplank on the new double-story 3Sep 11, 2007 12:42 pm Brick can only be placed on brick....
ie if the back wall of the house on both storiea does not line up then the upper will be something other than brick. Hope it makes sense. Matt I have reverted to username - mattwalker Carlisle Homes - Grande 43 My building experience is here: http://www.ourgrandeplan.blogspot.com Re: what is pros and cons of hardiplank on the new double-story 4Sep 11, 2007 12:59 pm My Allcastle home had hardi-plank at the rear. Well the display home did. I asked for brick. So they laid a steel beam across the rear of the house and did it in brick.
Like I said, it can be done.. it'll just cost extra $$$. Re: what is pros and cons of hardiplank on the new double-story 5Sep 11, 2007 1:11 pm Mark,
apologies I misunderstood your answer. It can be done! I forgot to read it obviously.... What sort of extra $$$ are we talking in your case? I have reverted to username - mattwalker Carlisle Homes - Grande 43 My building experience is here: http://www.ourgrandeplan.blogspot.com Re: what is pros and cons of hardiplank on the new double-story 7Sep 11, 2007 4:59 pm Does it worth 3-4k to just have a few square meter brick? Re: what is pros and cons of hardiplank on the new double-story 8Sep 11, 2007 5:10 pm Think about the work involved.
Extra beam to support weight. Extra reinforcement to hold up beam. Extra scaffold to get to area that needs bricking. Extra bricks/mortar. Extra time for brickies. Versus Sheets of hardiplank can probably be hung in half a day by 2 blokes. Slap some paint on afterwards. Re: what is pros and cons of hardiplank on the new double-story 9Sep 11, 2007 5:17 pm Mine cost 3k for the entire rear of the upper story.. about 15 metres across.
This was back in 1999. Re: what is pros and cons of hardiplank on the new double-story 10Sep 11, 2007 8:45 pm [quote="Al"]Think about the work involved.
Extra beam to support weight. Extra reinforcement to hold up beam. Extra scaffold to get to area that needs bricking. Extra bricks/mortar. Extra time for brickies. Versus Sheets of hardiplank can probably be hung in half a day by 2 blokes. Slap some paint on afterwards.[/quote] I total agree that there are a lot work to have the brick. It is cost saving for hadriplank. But for a long run, the hardiplank need to maintain regularly, and may not last long. Re: what is pros and cons of hardiplank on the new double-story 11Sep 11, 2007 11:07 pm I'd go the extra cost of brick .
The 2nd floor extension that was done on my place in the 90's is hardiplank and frankly - it looks F%$#@ ugly. Plain flat boring painted surfaces - and 13 years on the paint is fine - but man is it ugly and looks just like it is - a hardiplank bit plonked on top of a briock house and it is totally out of place.!!! I'm currently working on ways of improving it, with colourbond corrugated iron being one of them. Don't go the hardiplank option it is cheap and it looks cheap. !! Steve Re: what is pros and cons of hardiplank on the new double-story 12Sep 12, 2007 9:09 am Yak_Chat Don't go the hardiplank option it is cheap and it looks cheap. !! Steve Unless you cant see it and you don't plan on being in the house for a long time... in which case go ahead. I have reverted to username - mattwalker Carlisle Homes - Grande 43 My building experience is here: http://www.ourgrandeplan.blogspot.com Re: what is pros and cons of hardiplank on the new double-story 13Sep 12, 2007 9:32 am If the extract $$$ is reasonable, I take the brick. Otherwise find one which don't have the hardiplank, and make some internal modification, in this way it may be cheaper.
However, there are not many builder build 100% brick home now. When you drive along the new ester, you will find many new home with hardiplank. Re: what is pros and cons of hardiplank on the new double-story 14Sep 12, 2007 9:56 am You have other options too:
Colourbond cladding Rendered Blueboard etc... I have reverted to username - mattwalker Carlisle Homes - Grande 43 My building experience is here: http://www.ourgrandeplan.blogspot.com Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a… 17 12072 We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4099 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8505 |
