Browse Forums Building A New House 1 Apr 06, 2010 2:20 pm I have prestart this friday. I need to confirm what design the elevation needs to be. The front elevation is fully rendered. I need some ideas on color combinations, or some design work to the Portico etc... Can someone give me some ideas. thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Land - Northerly Estate, Piara Waters Titles Issues 05 April 2010 Building with Ross North Homes Prestart Completed 12 April 2010 Finance Approved 01 May 2010 Slab down 29 May 2010 Frame Completed 28 June 2010 Roof Completed 22 July 2010 Lockup 12 August 2010 PCI 24 Sep 2010 Handover 08 Oct 2010 Building Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=32295&start=0 Re: Elevation Ideas 2Apr 06, 2010 4:51 pm can someone please give some ideas or suggestions. I was looking at creme color front double door, corinthian door with glass squares running vertically. I was thinking of wood finish garage door. What color for roof ? will tile or tin roof be good for this elevation ? What paint color selecttion will be good ? Land - Northerly Estate, Piara Waters Titles Issues 05 April 2010 Building with Ross North Homes Prestart Completed 12 April 2010 Finance Approved 01 May 2010 Slab down 29 May 2010 Frame Completed 28 June 2010 Roof Completed 22 July 2010 Lockup 12 August 2010 PCI 24 Sep 2010 Handover 08 Oct 2010 Building Thread https://forum.homeone.com.au/viewtopic.php?f=31&t=32295&start=0 Re: Elevation Ideas 3Apr 06, 2010 9:26 pm Hi Mark, have you seen anything that you particularly liked in any of the display homes that you've seen? If so, why not ask the respective builder what colours they used and copy them? we've going with a 2 tone render on our house - 150% strength Solver Beaver for bottom half of wall and and 100% strength for top half. We've gone with colourbond monument roof & gutters, and 150% strength Solver Beaver for fascias. We've chosen Solver Pelt for our front door, and because I wanted a bit of a reddish colour to contrast, we chose colourgrain Caoba for the garage door. Hope this gives you some ideas to help you select your colours Building SOR with Dreamstart Homes Customised Dream Dior/Summer Sensation https://forum.homeone.com.au/viewtopic.php?f=31&t=83776 Re: Elevation Ideas 4Apr 06, 2010 11:04 pm I'd personally go with colourbond, and definitely with a lighter coloured roof. Remember that the darker it is the more heat is absorbs. Lighter colours reflect the heat. The following two images are your facade, and I have used the colours from the colorbond palette Shale grey roof, dune gutters, surfmist fascia. Choose a beigey/creamy colour that you like. Up to you if you want feature colours or not, but I think it will look classier with just a different colour for your pillars (a paler version of what you use elsewhere) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Same colours with monument roof and gutters, jasper fascia. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ From the tile ranges that you listed previously you can get tiles in these types of shades. You need to pick what look you like and then run with it. If you're interested in going for a paler roof take a look at mine - we have colorbond surfmist for roof, gutters and fascias (although fascia not painted yet) with dulux white duck render (full strength on front room, quarter on the rest). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I think it would also look nice to match your fascia to your pillars - so if you go with surfmist for fascia and pillars and some pale colour for your render you should be safe. You need to decide what kind of colour you want on your render. There are so many creamy/beigey colours available. Some are pink based, some brown, some yellow, some look more grey. It's up to you what suits your needs, and it is very personal. It will also look different in the daylight to any colour samples that you get. Re: Elevation Ideas 5Apr 07, 2010 11:10 am Re: Elevation Ideas 6Apr 07, 2010 3:52 pm mdzzj To help give you ideas, Dune roof, gutters, fascia and render. lovely =) I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6150 Hi guys We have just removed a very large grape vine which was mounted to a structure along this wall. This is a shared wall with our neighbour, and after removal, we… 0 3953 |
