Browse Forums Building A New House 1 Apr 06, 2010 12:56 pm Hi all, We have drawn up some rough plans to give builders an idea of what we want. Let me know what you think of the plans and what we should change as we are first home builders. Also we are looking for builders in the Hornsby (Sydney) area who could build this or something similar. Thanks Trent First Floor Plan http://i42.tinypic.com/1zgbak7.jpg Ground Floor Plan http://i42.tinypic.com/10wno1g.jpg Plan on site contour http://i42.tinypic.com/1zn7q6r.jpg Contour section 1 http://i41.tinypic.com/25zlchw.jpg Contour section 2 http://i42.tinypic.com/2ronzo2.jpg Re: What do you think of our plans 2Apr 06, 2010 2:15 pm That looks like a great plan obviously you have given good consideration to the slope of the block. I am jealous of all the under house storage you will have! My only thoughts are to maybe move the laundry downstairs (lots of room there) and re-organise the bathroom/powder-room to give you more space for the kitchen. Also, maybe consider moving the step in on the 'meals' wall closer to the kitchen (say 600mm back from the kitchen bench), this will be a nice feature to divide the meals and kitchen but will be easy to furnish - especially if you have a breakfast bar there. Building an Eden Brae Saville 27 http://karry327.blogspot.com/ Building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=44247 Re: What do you think of our plans 3Apr 06, 2010 2:28 pm What are you doing for natural ventilation for bedroom 4? Is there some sort of roof opening / window in the ceiling? Most councils will require some form of opening for any habitable rooms from memory (unless you name it something like a storeroom - this is what we were told during our planning days) Some things are worth waiting for. Re: What do you think of our plans 4Apr 06, 2010 8:57 pm Quote: My only thoughts are to maybe move the laundry downstairs (lots of room there) But is this on a sloping block so it is actually a split level house - if so, there would be hill behind the garage so the laundry upstairs will in fact open to level ground at the back. If so, It couldnt be downstairs anyway - there would be no natural light or opening at back of downstairs Am I making sense - I know what I mean, my parents house is split level like this - they also have a small sitting room next to the stairs, which has no natural light - got away with it by calling it "foyer" on their plan - in fact it is big enough for a couch and the TV unit which fits under the stair case Re: What do you think of our plans 5Apr 06, 2010 9:34 pm Hi Trent, It's great to have a starting point before going and seeing a builder, but I think there's a few things with this concept that aren't really working. As others have mentioned, bedroom 4 probably won't be passed as a habitable room in its present location. I'm also not sure about the location of the dining room - it's a long walk from the kitchen. I'd also flip the shower and toilet in the en-suite to create a more free flowing space. Do you have views from your block? If so I'd be looking at maximising these with the design. Also, rather than having the kitchen at the back of the house, you could try moving it in to a more central location with living &/or dining spaces on either side which would give the home a living space facing the back yard. Have a look at this design: http://www.tullipanhomes.com.au/detailed.asp?HID=28&p=1 (just imagine it flipped from left to right) or this one which has a separate rumpus room: http://www.tullipanhomes.com.au/detailed.asp?HID=218&p=1 Re: What do you think of our plans 6Apr 07, 2010 8:53 am Hi Trent, Have you had a read of Greg's thread viewtopic.php?f=31&t=29899 ? He has a great builder, and is building in HSC. Also, you will find some other H1 members who are in HSC who may be able to help you. Cheers Bel Still not in. Don't ask!? Re: What do you think of our plans 7Apr 07, 2010 9:21 am Hi Trent. Definitely a good start. Like others have said, bedroom 4 will be an issue. Also the dining room location doesn't work for me (you may have intentionally had it a distance from the kitchen and closed off?) I also think the laundry/bathroom area could use some work. I'm sure once you take it to the builder it will be fantastic! She's backkkkk... Re: What do you think of our plans 8Apr 07, 2010 10:20 pm Thanks to everyone for your comments. Karry, Kyton and Sharee, I have changed the plan around based on the suggestions. http://i40.tinypic.com/2jdkhtk.jpg I guess this will give the builders some idea of what we are after. I will leave the detail to the experts. Helyn, yes you are correct with the split level. Bel and Ikon, I have also contacted the two builders suggested so we will see how it goes. If anyone else knows of any other builders in the area that I should consider then please let me know. Thanks again. trm No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6632 Really tight at the top of the stairs- how to get furniture into those rooms? Study books - does anyone really use them these days? Large storage closet would be more functional. 2 6885 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 13771 |
