Browse Forums Building A New House 1 Apr 02, 2010 8:54 pm I've seen quite a few threads and never really noticed any plumbing pipes running on the outside of the stud wall. Should I be concerned about this? I can only imagine it is the quickest way to install. Thanks ahead for the advice
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: advice: plumbing pipes on outside of stud wall? 2Apr 02, 2010 9:13 pm hmm, this is a bit unusual but I am a layman so hopefully a brickie can see your post and give some comments. All pipes are run internally for my build. Not sure if it's going to be harder to brick & maintain a vertical plumb line with all the pipes running externally though, have you checked with your SS? Re: advice: plumbing pipes on outside of stud wall? 3Apr 02, 2010 9:31 pm How else where you guys thinking it should be done?? Plumbers dont normally drill through the studs it is too difficult. Personaly I prefer to have the pipes done first and then the sarking on top. This just gives the pipes a little extra protection for the heat. Eiter way the pipes will still be on the outside of the stud wall. Re: advice: plumbing pipes on outside of stud wall? 4Apr 03, 2010 8:14 am Hey tuned86, yep the way they've done it is the quickest way about it. As long as all the pipes are secured properly you shouldn't have any concerns. A lot of companies do install their pipework outside of the frame, however it's still inside the wall cavity (between the bricks and timber) Re: advice: plumbing pipes on outside of stud wall? 5Apr 12, 2010 9:46 pm Thanks for the responses. I'm so use to seeing the pipes run in roof or alone stud walls, but its confident to know that this is how its done. My concern was if there was enough space between bricks and studs and also from a maintaince view...wouldn't want to be replacing those pipes anytime soon. Re: advice: plumbing pipes on outside of stud wall? 6Apr 13, 2010 7:10 am If the plumbing and electrical wiring was inside the frame, how would the plaster fit over it, since the sheets are screwed to the frame? It has to go in the wall cavity. Sometimes the wall wrap goes over it, if the plumber has been quick off the mark and been on site before the frame is wrapped, but most of the houses around here have plumbing on the outside just like this. Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17849 4 5117 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5727 |
