Browse Forums Building A New House 1 Mar 31, 2010 4:34 pm Hi everyone, my partner and I have decided to paint the interior of our newly constructed home over the course of 2 weeks from Easter (we're young and naive ). We have a white plaster set over a float, not plaster boards, and we were curious to know if a sealer-binder (we're considering Dulux Sealer Binder, an oil based prep coat) can be applied straight to plaster or if surface preparation needs to be done first (wiping down with a damp rag, dusting, sanding etc.) Should we find any chips, can a normal spak filler be applied straight to plaster and sanded or do they need surface preparation too? Thank you! Re: Sealing fresh plaster for painting 2Mar 31, 2010 4:36 pm I'm interested to hear the answers to your questions as well V!! Although i won't be putting it into practice for between 3 to 6 months LOL viewtopic.php?f=31&t=22766 - my build thread! Time waits for no man. Unless that man is Chuck Norris. Re: Sealing fresh plaster for painting 3Mar 31, 2010 5:09 pm We had our PCI this morning and our SS told us we would need to patch the walls with some kind of filler to the dents, holes, scratches... and then sand it a bit. Then it should be ready for oil based sealer. I would also like to know the ans for this. We are also thinking of doing it ourself. Re: Sealing fresh plaster for painting 5Mar 31, 2010 5:34 pm I've found this PDF from Dulux dealing specifically with set plaster surface preparation: http://www.duspec.com.au/duspec/file/PFP021.pdf and their oil-based sealer binder: http://www.duspec.com.au/duspec/file/AUDD0074.pdf Re: Sealing fresh plaster for painting 6Mar 31, 2010 8:18 pm yup that's the one vunderful. make sure you keep the room aired when painting as the fumes are VERY potent! Re: Sealing fresh plaster for painting 7Mar 31, 2010 10:32 pm Get the gyprock final finish plaster coat, get broadknife...fill dents and divots....sand lightly with float and fine grit paper, dust off. Then get oil based sealer binder prep, the one starting with D is a good one. you can use an acrylic topcoat over the sealer coat if you want. Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5025 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6709 DIY, Home Maintenance & Repair Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only… 0 1756 |
