Browse Forums Building A New House 1 Mar 19, 2010 5:46 pm I guess you're in a good reception area and the cable itself is enough to pick up a signal. In the early days of colour TV I fluked a GE "fringe reception" set....there were a few of these imported from Japan when the stocks of standard models became a bit low. Well, we were 5km across a valley from the TV towers and that set didn't need ANY wire or antenna (even indoor) to give a perfect picture. In those days, every dollar counted and we happily didn't bother with an outside aerial. Unfortunately, it went in a burglary and the new set that replaced it definitely needed an outside antenna. BTW, my understanding is that digital reception is a bit of an "all or nothing" phenomenon. If you get a good signal with no dropouts or pixellation, that's all you need and it's as good as it gets. Using a better aerial will not achieve any further improvement (unlike analogue) Cheers zeke Re: TV Point question 2Mar 19, 2010 5:57 pm zeke I guess you're in a good reception area and the cable itself is enough to pick up a signal. In the early days of colour TV I fluked a GE "fringe reception" set....there were a few of these imported from Japan when the stocks of standard models became a bit low. Well, we were 5km across a valley from the TV towers and that set didn't need ANY wire or antenna (even indoor) to give a perfect picture. In those days, every dollar counted and we happily didn't bother with an outside aerial. Unfortunately, it went in a burglary and the new set that replaced it definitely needed an outside antenna. BTW, my understanding is that digital reception is a bit of an "all or nothing" phenomenon. If you get a good signal with no dropouts or pixellation, that's all you need and it's as good as it gets. Using a better aerial will not achieve any further improvement (unlike analogue) Cheers zeke Correct, although if the signal strength is marginal, an event like heavy rain between the transmitter and you might be enough to tip it over to no reception. In that case a better antenna (or in this case an antenna!) would be worthwhile. Pfiff Finally making progress again, with a clothesline (yippee) and some much needed little things being attended to over the holidays. 40 C on New Year's eve? We love our a/c! Re: TV Point question 3Mar 19, 2010 7:38 pm Sometimes the gods are with us - even in technical matters! Pfiff Finally making progress again, with a clothesline (yippee) and some much needed little things being attended to over the holidays. 40 C on New Year's eve? We love our a/c! Building Standards; Getting It Right! Hi All, We have a fall from road to garage front. But we cannot put a drain/grate because no discharge point put by the builder. Now they complain not enough space for… 0 9242 Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6524 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9960 |
