Browse Forums Building A New House Re: Site Cost around Mount Waverley 2Mar 17, 2010 2:27 pm Hi Yellow I don't know about Mt Waverley in particular, but I do know that most volume builders hate sloping blocks and will charge you big $$ if your block has any sort of slope. I am building in Croydon, and both Metricon and PD quoted between $15,000 - $20,000 site costs for our block which has just over 700mm fall. I had smaller builders quoting $5,000 - $10,000. 700mm fall doesn't look like a whole lot, but apparently it is. Good luck! If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8315 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37150 Thanks for the insight! My plot is a new development so hopefully I won't have too much problem during build as everyone should be roughly building together. I also… 2 3373 |
