Browse Forums Building A New House Re: HENLEY : Building my first Home " Regatta Q1" 33Mar 22, 2010 2:49 pm fruitty bek7708, Once you pay the initial $850 deposit and your land is available for soil testing let them know they will get it tested prior to tender. The next stage after initial deposit is the colour selection then tender. At tender the will give you the total price of what it will cost to build the house. There should be no extra charges (except provision for rocks) from this point. You can then walk away if you can afford to build (and obviously lose your deposit). You will have to pay the tender deposit amount to make up 3% deposit (if this has not change or I have forgotten). After tender they will draw up everything that you have agreed to at tender. You then come in for contract signing. NO backing out from this point. You will also need to pay the remaining to make up your 5% deposit (if this has not change or I have forgotten). Thanks so much Bek I'm back Hi, If you give a set of criteria as to what means 'good' to you, it'll give others prompts to respond. We considered Henley early on but there were two factors that… 1 10506 So it looks like we finally have some movement on site! Definitely later than expected, but I'll take any progress at this point. I'll drop by over the weekend to get… 5 27713 Can anyone give me any onfo on New Homes WA? Good or bad, hopefully good just need to know if my choice was good or not? Thanks ❤️ 0 8938 |
