Browse Forums Building A New House 1 Mar 14, 2010 7:45 am We are being told that we will need to move our meter box from the side of the garage to the other side of the house, which is on the external wall of one of my daughters bedrooms. We need to do this because we have extended the garage and apparently there won't be enough room to fully open the meter box as a minimum clearance of 800mm is required. We did ask them to recess the meter box into the garage wall, but apparently there still won't be enough room. I am concerned about having the meter box outside a bedroom. Does anyone know if there are any problems associated with this? Thanks Building the Grandview 36 with M$tric0n Plans approved 15/4/2010 Site start date 21/5/2010 Our build thread: viewtopic.php?f=31&t=32825&p=461266#p461266 Re: Is it safe to have a meter box on a bedroom external wal 2Mar 14, 2010 7:54 am I wouldn't worry about it at all. If you are super cautious, just make sure the bed is at least 2 metres from the meter box. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Is it safe to have a meter box on a bedroom external wal 4Mar 14, 2010 9:32 am I tried to move the meter box to the garge wall and they wouldn't do it (my garge external wall is just brick) So I have it on my bedroom wall. I've been told there is no prob with it. Bedroom certainly isn't big enough to have it 2 metres away from my bed! It prob. no more than .5 metre! A lot of houses I've seen have the meter box on the external wall of the bedroom at the front...along with the gas etc. Is this really an issue?? guess if it is, its to late for me as I'm already bricked up Re: Is it safe to have a meter box on a bedroom external wal 5Mar 14, 2010 9:53 am Frogger A lot of houses I've seen have the meter box on the external wall of the bedroom at the front...along with the gas etc.( Not sure, but think there are regulations about how close the gas and electricity can be to other things, especially to each other. Personally, I don't think I would be too bothered, but would still prefer it being on the garage side of the house. You could probably get it relocated "at a cost" if it was a problem. Re: Is it safe to have a meter box on a bedroom external wal 6Mar 14, 2010 9:56 am Didn't think there was any issues at all... in my current place we have the meter box on a bedroom wall above the gas meter and water meter all in the same 500mm x 500mm vicinity??? They're just meters aren't they? Why would there be any issues?? (please excuse my ignorance if there should be an issue glaring me in the face!!!) Sleven Moved into our Atlantique MkII 36 by Carlisle Homes Re: Is it safe to have a meter box on a bedroom external wal 7Mar 14, 2010 10:05 am sleven Didn't think there was any issues at all... in my current place we have the meter box on a bedroom wall above the gas meter and water meter all in the same 500mm x 500mm vicinity??? They're just meters aren't they? Why would there be any issues?? (please excuse my ignorance if there should be an issue glaring me in the face!!!) I think the issue is the same as overhead high voltage lines; electromagnetic radiation. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Is it safe to have a meter box on a bedroom external wal 8Mar 14, 2010 10:38 am mmmmm ours is all on our main bedroom's wall, didn't think anything of it as it couldn't go the other side anyway due to neighbours garage and fence in teh way......will just make sure hubby sleeps on the side of the bed closest to it Caz & Co ALL MOVED IN!! Now comes all the hard work-decorating.... [b]Blog: http://cazoraz.blogspot.com/ Settling in Thread: viewtopic.php?f=31&t=36993 Re: Is it safe to have a meter box on a bedroom external wal 9Mar 14, 2010 11:02 am cazoraz .....will just make sure hubby sleeps on the side of the bed closest to it Someone is too sweet. NO EXPECTATIONS, NO DISAPPOINTMENTS! Build Thread: viewtopic.php?f=31&t=27441 Landscaping Thread: viewtopic.php?f=19&t=43969 Re: Is it safe to have a meter box on a bedroom external wal 10Mar 14, 2010 12:05 pm The bedroom in question is my youngest daughters bedroom and she can be a real little you-know-what. Maybe the radiation or whatever will turn her into a good child Building the Grandview 36 with M$tric0n Plans approved 15/4/2010 Site start date 21/5/2010 Our build thread: viewtopic.php?f=31&t=32825&p=461266#p461266 Re: Is it safe to have a meter box on a bedroom external wal 11Mar 14, 2010 12:41 pm When PubMed (which comprises citations of articles from various medical journals) has hundreds of results for a search on electromagnetic fields and the Australian Radiation Protection and Nuclear Safety Agency has produced literature on how to go about measuring residential electromagnetic fields, then it's obvious questions have been raised. I think the jury is still out somewhat as to what is safe and what isn't, otherwise hopefully the building code would have been amended. But we chose to be cautious in this and our previous house, and not have bedrooms backing onto the meter box or any major appliance like the fridge. Re: Is it safe to have a meter box on a bedroom external wal 12Mar 14, 2010 12:50 pm Northbound The bedroom in question is my youngest daughters bedroom and she can be a real little you-know-what. Maybe the radiation or whatever will turn her into a good child clearly you havn't seen too many movies and such ..it usually radiation has the oppisite effect.. Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Is it safe to have a meter box on a bedroom external wal 13Mar 14, 2010 1:44 pm I've seen some houses where they have extended the boundary wall of the garage forward from the otherwise start of the garage, and then placed the meter box on that wall facing in to the driveway. No worries about having enough space to open it unless you park your car in the driveway too close to the wall (but then you'd likely have problems opening your car door anyways). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Is this an option for you? Re: Is it safe to have a meter box on a bedroom external wal 14Mar 14, 2010 4:29 pm This issue has been raised before - I really dont think there is any problem. Our meter box is on our bedroom external wall, hasnt caused any problems whatsoever. Re: Is it safe to have a meter box on a bedroom external wal 15Mar 14, 2010 4:34 pm Yeah, I don't think there's a problem with it. The only reason I don't like the idea, is if it means the metre reader has to walk past your bedroom window. Why else would it be a problem??? Land settlement 4 May Building contracts signed 27 July Slab pour 26 March Frame started 10 May Bricks start 31 May Roof & Gutters Start 31 May gyprock 1 July Kitchen & cabinets/tiling 19 August Second fix plumbing 15 September Second fix electrical 22 September PCI 28 September viewtopic.php?f=31&t=29155 Re: Is it safe to have a meter box on a bedroom external wal 17Mar 14, 2010 6:28 pm I don't have a problem with our meter-box being on the bedroom wall, any more than I worry about preservatives in food, mobile phone usage, high voltage power lines, and the possibility of an asteroid hitting the earth and wiping out all life Admittedly, being in WA we have double brick construction so any potentially high-energy electromagnetic radiation is unlikely to breach the metal box, bricks and plaster Re: Is it safe to have a meter box on a bedroom external wal 19Mar 14, 2010 7:09 pm I would never have it next to a bedroom, and if it has to be – then a far wall (and ideally double brick etc etc) EMR (Electro magnetic radiation). Its real! But obviously power company's, phone company's don't advertise it. Here is a good website with info about the subject. www.yshield.com.au You may of seen 'Australian Story' on Red Symons son who has developed cancer (their house was next to a sub station'. Whether you are a 'believer' or not, why take the chance with your health and that of your loved ones? and just have it somewhere else. You may not be able to stop an asteroid from space but you can do something about this. Remember asbestos was once considered a fantastic building product? Re: Is it safe to have a meter box on a bedroom external wal 20Mar 14, 2010 7:25 pm My meter box has been on my bedroom wall for the nearly 22 years since we built. Never had a problem except for when it's windy and the latch decides to undo and you get it banging all night. Lynette ~making my dreams come true Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3503 |
